Michael Delaney wanna-be
Netspeed's Avatar
Swepco 306 question
I got an 88 Carrera in SoCal. Nice weather now but gets pretty hot in the summer. I've got about 160k miles on it. What weight oil would be recommended? Seeing that Wayne sells it I'm assuming it has all the great ZDDP stuff.....
88 Carrera Cab
C.R.A.P. Gruppe Member #7
Old 01-11-2008, 01:50 PM
just me
paulgtr's Avatar
Send a message via Yahoo to paulgtr
Ultimate Motor Oil Thread or Why we hate CJ4/SM oils
maybe this is the equivalent of using a howitzer to kill a mosquito
but that thread has all the answers and makes a lot of sense
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses.
http://www.hairydoggrrrage.com/
Old 01-11-2008, 02:01 PM
Netspeed's Avatar
I have read that thread and didn't find any info specific to my local. I was hoping someone local could help out. Also, it's just a daily driver but with LA's freeways they are (more like parking lots), it's almost like driving on the track (heat that is).
88 Carrera Cab
Old 01-11-2008, 02:11 PM
just me
paulgtr's Avatar
I thought there was a chart showing which ambient temperature range fit with which grade of oil
like right now i am using 5w30 brad penn racing oil
Old 01-11-2008, 02:13 PM
Netspeed's Avatar
You're right....my bad. It was on page #4 of the thread about haf-way down.
Thanks for all your help!
88 Carrera Cab
Old 01-11-2008, 02:28 PM
just me
paulgtr's Avatar
no worries.
that thread is a real resource when it comes to oil questions
Old 01-11-2008, 02:30 PM
Netspeed's Avatar
It is....I'm surprised it isn't a sticky.
88 Carrera Cab
Old 01-11-2008, 02:31 PM
just me
paulgtr's Avatar
subscribe to it
or just bookmark it
that way you can always find it
Old 01-11-2008, 03:04 PM
GrantG's Avatar
I think you'd be fine with 15W40 (what I use) or 20W50.
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 01-11-2008, 03:08 PM
Netspeed's Avatar
Originally Posted by paulgtr View Post
subscribe to it
or just bookmark it
The thread is easy to find for the Pelicanites that have been on here awhile. I meant they should make it a sticky and title it "Everything you wanted to know about motor oil" or something like that for all the new people that join the board.
88 Carrera Cab
Old 01-11-2008, 03:30 PM
just me
paulgtr's Avatar
true.
or atleast it should be part of the resource that Wayne is trying to put together of all the different technical help issues that have been discussed here over the years
Old 01-11-2008, 03:32 PM
Netspeed's Avatar
true.
I don't envy that project!
88 Carrera Cab
Old 01-11-2008, 04:09 PM
efhughes3's Avatar
There are a ton of relevant/important threads on here. We'd have 2 pages of stickies if they were all immortalized. Besides, that's half the fun here, wading thru all of the info.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 01-11-2008, 04:17 PM
I agree with you Netspeed . I'm in the s.f. area however my baby is more a garage queen.. Excellence May 2004 has an article by Jim Pasha on motor oil .He suggest using 15w-50 year round for 89-and -earlier 911s because of high heat- both ambiemt and engine.
Old 01-11-2008, 10:09 PM
just me
paulgtr's Avatar
totally agree
I do searches sometimes and wind up going completely off the topic following the threads that pop up.
I mean every single topic is still here from the beginning
boggles the mind
Old 01-11-2008, 10:28 PM
SoCal. ......gets pretty hot in the summer.
I've spent some time on same roads.
If I lived their permanenty I'd add another oil cooler under left fender.
If I can't keep at least a very slow roll I'll keep the revs at 1,200 to at least stabilize the electrics, have "some" air flow over engine, and keep oil flowing to coolers.
Mobil 1 15w50 is more than ok imo.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-12-2008, 04:21 AM
Netspeed's Avatar
It's scary sitting on the freeway in 100 degree weather going 5-10mph and knowing that you have 20 miles to go. I did them same thing...try to keep the revs up to about 1500rpm.
From what I've read, I'm sticking with dino-based oil. I know many have not had problems with leaks but I don't want to risk it.
88 Carrera Cab
Old 01-12-2008, 05:42 AM
efhughes3's Avatar
I think I'd respectfully disagree there. From what I've read, Mobil 1 has been one of the bigger changes in formulation these last few years. Sure, Porsch may still recommend for new cars, but they are different animals.
There are too many boutique oils out there that will do better for our cars. I was going to run Brad Penn 20/50 for only my break-in, and then switch to full syn like Redline or RP, but I think I'm sticking with it. It's a semi-syn, which is what I've run for the last 6 yeats (different brand) and I was pretty impressed with how my engine looked when I took it apart for rebuild.
Not that I'm trying to be cheap here, but it is also about 1/2 the price of Mobil 1.
Ed Hughes
2015 981 Cayman GTS
Old 01-12-2008, 06:44 AM
Mobil 1.
I only said Mobil 1 is "more than ok imo".
So you figure it's not ok?
If I had to change from that I'd use Redline.
The important part of the reply is the added front front oil cooler, especially with dino oil.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-12-2008, 07:56 AM
efhughes3's Avatar
I wouldn't say it's more than OK, it is held in somewhat false esteem, IMO, because of what it USED to be like. The ZDDP issue is nothing to gloss over, and I thought I'd read that Mobil 1 is one of the oils that reduced it significantly. I'd change from that to Redline in a heartbeat, if you want full syn.
I've had my '84 in Texas heat with only the stock coolers at the track and on the street, and have never overheated or come close.
I guess I'm just more sensitive to this whole deal having just done my rebuild, and knowing what I spent in time and money. It is not something I plan to do again on this car.
That, or I guess I'm just argumentive today...
Ed Hughes
2015 981 Cayman GTS
Old 01-12-2008, 09:41 AM
