NEWFIE 69 911E's Avatar
Question Damp garage, storage tips to stop rust?
Happy New Year all (late I know)!
This winter I have to store my ROW 1980SC in an unheated garage. It is bound to get a little damp due to the variable climate here in Newfoundland.
Do any of you fellow Pelican's have any suggestions re temporary sprays or coatings to prevent rust from forming on the brake discs, Fuchs, etc?
I have considered purchasing a Car Bag to keep the car dry - do any of you have experience with these, or other similar bags?
Happy Motoring
In stable: 1980 911SC Targa RoW Guards Red
1969 911E Coupe
Old 01-12-2008, 11:39 AM
AutoBahned
RWebb's Avatar
BEST: Heat it or use a dehumidifier
2nd Best: Use a fan and insulate it to reduce temp. swings at night
ALSO: do NOT use a car "bag' (unless it is one with a fan) that will trap humidity in the enclosed space.
Spray LPS, Boeing T-9 (?) Tectyl or similar over every surface.
Expect the leather to get moldy and fabrics to rot...
Sure you can't put it anywhere else?
Also, keep it as far as possible from the ocean, from ocean winds and salt spray.
Old 01-12-2008, 12:11 PM
Don't worry about the brake discs. Won't hurt a thing.
Fuchs won't rust. If they do, they aren't Fuchs.
Remove the battery.
Put a couple old tupperware tubs of rock salt inside the trunk and floor of the car. Don't fill them full of salt. Maybe 1/2 full. The salt will absorb the moisture and keep the interior relatively dry. You may need to change the salt every few weeks or so. In Florida we used to put a frisbee full of salt on the floor to keep the interior from smelling musty.
Hopefully not an earth floor, although concrete is not a lot better.
How big is the garage? Small one-car? Can you cover the floor with plastic? Heavy plastic drop cloths from Home Depot? That would help a lot.
Old 01-12-2008, 01:28 PM
Having lived on the rock I can appreciate the difficulty you're having. If I was back there with my 911 I'd take it to someplace like Krown and have her treated prior to storage. The thin oil they use gets into all the little nooks and crannies displaceing the water plus it'll also discourage the neighbourhood stray cats from taking up residence Treat your leather with a good leather treatment product to protect it. Considering the humidity there I'd fill the gas tank so theres not much airspace in it, Add some fuel stabilizer to keep the varnishs and gums from forming and you ought to be OK.
'83 SC Coupe
Old 01-12-2008, 03:44 PM
Party Member
viejopatron's Avatar
My buddy uses a bubble bag on his seldom driven '89 speedster widebody. Seems to work; keeps critters and the marine air off the car. How about using a bubble and a desiccant in a cat box?
Gary
71 911T Miss Demeanor / 2013 Audi Q5 Hundeführer / 1995 993 Miss Adventure
Old 01-12-2008, 04:47 PM
I keep a window fan on all year. It's not perfect but it helps a lot.
I live on a sandbar.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-12-2008, 05:59 PM
Zeke's Avatar
+1 on Krown products. I've had success with the US equivalent on my machinery that I have to keep covered and out on a slab/car port. Two years ago the concrete became saturated and I ran fans 24/7.
Old 01-12-2008, 06:03 PM
Thanks for the suggestions and tips. At this point I don't want to drive the car on to the local Krown dealer for treatment, but I will try to get some spray cans of their product.
Some of you like Car Bags, some do not. Me thinks a Car Bag might be the best way to keep the sea air away from the car.
The garage is new, 24' x 20', with a concrete floor. In the spring I plan to finish it, with insulation and heat!
1969 911E Coupe
Old 01-13-2008, 05:18 AM
Brad w's Avatar
I have heard that charcoal works good.
Brad W 1980 911 SC
1982 928 Auto
1982 928 5spd Comp PKG
2005 SLK 350 w/ AMG Pkg
2007 Hummer H3
Old 01-13-2008, 05:41 AM
old man neri's Avatar
I forget, is Krown one of those places that drills holes in your car when treating it?
Old 01-13-2008, 06:31 AM
I'm with Bill
Rick V's Avatar
Check your PM's
Old 01-13-2008, 06:41 AM
Automotive Writer/DP
Randy W's Avatar
Leave a light bulb on.
1972 S - Early S Registry #187
1972 T/ST - R Gruppe #51
http://randywells.com
http://randywells.com/blog
Old 01-13-2008, 07:05 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Heat is your friend...Ho..and I like you nickname a lot...
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 01-13-2008, 09:13 AM
DanielDudley's Avatar
I assume you put a vapor barrier under the concrete. If so, just putting a couple of drop lights under the car will do a lot. Make sure you have all your weatherstripping in place around the doors etc. Set mouse traps.
Old 01-13-2008, 09:26 AM
p911dad's Avatar
Newfie, I keep the 911 in an unheated barn on a concrete floor deep in upstate NY, near many lakes. We have some humidity here in the winter, but what is especially bad is when the air warms up suddenly after a cold snap, the cold metal of the car acts like a cold sink, and the underside gets all wet from the moisture wicking up through the concrete floor. I successfully ended that problem with a large( I mean Large) sheet of heavy plastic that I covered with some old sheets of 3/8 inch plywood. It acts as a cheap moisture barrier. An old box fan($10 item) in the corner keeps the air moving. No more problem. Glenn
Old 01-13-2008, 12:37 PM
Awesome tips! Please keep them coming!
1969 911E Coupe
Old 01-13-2008, 04:47 PM
MrScott's Avatar
This thread on garagejournal suggests:
a) Purchase a hygrometer to measure the effects of whatever solution you choose
b) Rock salt bags are simple and effective
c) A properly sized dehumidifier can work well
1980 911SC
Old 01-13-2008, 07:26 PM
I'm currently using a car bag with the drying bags inside (both the interior and bag). Pop out windows open, and front windows down a couple of inches. I'm very happy with it so far.
John
(Fellow Canuck)
Old 01-14-2008, 02:12 PM
MikeTheYounger's Avatar
They sell desiccant cylinders see...........http://www.mcmaster.com/ page 651 item 2202K66
When full you throw in the oven and "recharge" the cylinder.
Mike Serrone Jr.
2008 Candy White 2DR GTI DSG :: 1980 SC (Father/Son Track Toy)
///BrooklynAutoRennen | Rudtner's Racing Group | Tyrolsport
Old 01-14-2008, 02:30 PM
RF5BPilot's Avatar
If your garage has electricity, I have had very good luck with "air dryers" for boats.
For example:
http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/245832/377%20710/0/air%20dryer/Primary%20Search/mode%20matchallpartial/0/0?N=377%20710&Ne=0&Ntt=air%20dryer&Ntk=Primary%20Search&Ntx=mode%20matchallpartial&Nao=0&Ns=0&keyword=air%20dryer&isLTokenURL=true&storeNum=5002&subdeptNum=12&classNum=380
I use a slightly oversized cotton car cover (the cotton still allows some air movement) and put the boat heater under the car. I have not used one of the heaters that have an internal fan. I didn't want any sparks. The ones I have use about 75 watts, won't burn out, don't have a thermostat--so no sparks and put out just enough heat to create something of a dry envelope around the car. This has worked well with several european sports cars from the 60's whose metal seems able to manufacture rust in a desert.
James
Old 01-14-2008, 03:06 PM
