Anarchist Extremist
OK wait a minute here, I think I can dig most of this.
AFR = Air Fuel Ratio FV = Fuel (valve)? WOT = Dunno this one right,wrong? thanks!! and keep going I still havent made up my mind.... Chris
80 SC Coupe 00 Tundra (Tow Rig) 00 Audi A6 Avant (wifes rig) 03 Wife ('71 typ Spezial) 05 Kid (MENSA prototype) |
You got the first one, second one is Frequency Valve, last one is "Wide Open Throttle."
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
Anarchist Extremist
Scott R - how does the frequency valve work? what were is it.
PS looks like I will have a similar set up as you sans the JE's 1980sc (US), 964 cams, SSis (or early boxes), 2 in one out. Chris
Starting with the 80' there is a fuel line attached to the back of the fuel distributor, and in-line with that is a modern day fuel injector to add enrichment. This injector has a 12V supply form the front relay and its grounded by the fuel enrichment computer under the passenger seat. For the 80's it was a pretty genius device.
Chris wrote,
how does the frequency valve work? what were is it. Chris, The FV is a pulsed injector used as a variable pressure restrictor for the fuel pressure in the lower chamber of the fuel distributor. All modern fuel management systems dither the mixture rich and lean of stoich for the benefit and life of the cat. The FV is an add on to CIS to allow electronic control of the mixture and, unlike previous CIS systems, the FV circuit must be pulsing in the mid range to get the correct fuel curve. I suggest you read the Bosch manual or Probst's book if you want to understand the system. If you have a dwell meter, you can get a start understanding the system by connecting to the test port and watching the duty cycle during cold start, open loop and closed loop after warm up. It will tell you if the system is working properly and allow you to adjust the mixture.
Paul |
Someone told me that it is supposed to buzz when the ignition is on. True? |
Somatic Negative Optimist
![]() I understand the enrichment was done electronically effecting the FV, NO additional fuel injector. There were additional components from'81 on; the CIS became quite complicated to satisfy emission control requirements. The FV on an '80 has a different duty cycle than '81-'83. They all buzz and you can feel it when the engine is running. Back of the fuel distributor means facing the bulk head (Towards the front of the car) Reading a book on the Bosch K-jetronic CIS will help to fully understand the system.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Yes, the '80 doesn't have the additional AECU plugged into the Ox Sensor Control Unit under the seat.
See psalt's excellent explanation below.
Scott wrote,
I suppose I did, maybe its for lack of better terminology, the FV is "controlling enrichment" in a certain way, however it may not be adding any under accel on the 80. Would that be correct? Hello Scott, No, all lamdba CIS models provide acceleration enrichment by going open loop after 35% throttle and reverting back to the fixed cold duty cycle (higher duty cycle, lower pressure, richer mixture). The 81+ refinement was to lower the fixed cold duty cycle spec and add a cold acceleration enrichment system that uses a temperature sender on the breather, another throttle switch and another control unit. Sort of a band-aid on a band-aid. This was to reduce emissions during cold warm up without a lean stumble on acceleration.
Paul |
By design. The switch is a three terminal (3,18,2) black box on the back of the throttle body. The additional cold enrichment switch looks like the micro switch on an early CIS system and is over by the throttle linkage. It should be set to open at 15% throttle. The easiest way to test the main throttle switch is at the main temperature sender on the chain case.
Paul |
Both switches are on/off, not continuous, they are positioned to open at different throttle angles. The 80 switch should be connected to pins 3, 6 and 2 on the control box and trigger the system to go open loop. If the switch you are looking at has only two terminals, it may be the micro switch from an 81. Take a look at the wiring diagram.
Paul |
Anarchist Extremist
yOWZA! I am going to look this all up in my bosch book.
I know where to come if I have running issues, which I am sure I will. I still am not convinced of whether I should keep my o2 sensor or not. I have the capabilities to richen it up to 3% I believe it is? Chris
Anarchist Extremist
probably wouldnt work if I unhooked the FV, and the o2...
eh? Chris
No, when the FV dies, or more commonly when the relay up front that powers it dies, the SC's run like crud.
Chris wrote,
I know where to come if I have running issues, which I am sure I will. I still am not convinced of whether I should keep my o2 sensor or not. I have the capabilities to richen it up to 3% I believe it is? Chris, My advice would be to spend the $5 and fit a bung to what ever exhaust you choose. That way you can run the stock sensor, or fit a plug. Once you understand the system and see how easier it is to diagnose, check the mixture and adjust it, it will be much clearer. You cannot unhook the FV, it blocks the pressure line and leans out the fuel curve too much.
Paul |
Designer King
Chris,
AFAIK all that stuff has been removed from my engine, and it runs great. The key may be to make sure if something is removed, then everything should be.(?) I have a different , earlier style, WUR, one that allows WOT enrichment via vacuum.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 01-17-2008 at 05:01 AM.. |
