-   -   What to replace clock with?-INTERESTED? (http://forums.pelicanparts.com/porsche-911-technical-forum/388103-what-replace-clock-interested.html)
marks914 01-19-2008 04:12 AM
Hey All,
I have been doing custom gauges for folks in the 914 and hot rod communities for about a year and a half now. My work as a designer and gauge customizer has been shown in several publications as well. I am in the process of converting over a set of 911 gauges to V8 use and it occurred to me that the clock is kind of useless if there is one in the radio. This could be a spot for some more pertinent information.
I was going to use a fuel gauge and retrofit it with a voltmeter and CHT gauge. What other types of gauges would you like to see in there? I can fit any VDO 90 degree sweep gauge in there. Anything else?
Mark
http://inlinethumb53.webshots.com/41...600x600Q85.jpg
http://inlinethumb25.webshots.com/27...600x600Q85.jpg
http://inlinethumb02.webshots.com/39...500x500Q85.jpg
http://inlinethumb08.webshots.com/38...500x500Q85.jpg
http://inlinethumb61.webshots.com/76...500x500Q85.jpg
wolf 01-19-2008 06:22 AM
I saw an SC, prepped for circuit, with a big red warning light where the clock used to be. I guessed it was for low oil pressure.
TRE Cup 01-19-2008 08:28 AM
"guages? GUAGES?! We don need no steeken guages!"
just had to do it :)
besides the clock hole oil press lamp, it has also been used for a ventilation duct, LED or mechanical boost guage on 930/935. Porsche used to offer an outside temp guage on the 356 and early 911, and with the trick 3 and 4 in one set ups you pictured, you can also monitor transmission temperature, put the boost there and place a small clock on the bottom of the tach
al lkosmal 01-19-2008 09:56 AM
Air/fuel mixture gauge
Moses 01-19-2008 10:10 AM
I always wanted a Valentine-1 concealed display mounted in the tach or in the spot where the clock goes.
http://forums.pelicanparts.com/uploa...1200766238.jpg
TRE Cup 01-19-2008 10:16 AM
mark
there is a guy down here in the chatsworth area that does super custom deals like that. he even can take thicker rear view mirrors apart, remove the silver in one corner, and put in a radar display. There are other trick things he does too with regards to radar- best not to discuss here
signature65 01-19-2008 11:44 AM
I always thought the big red light was a Shiftt light. You see it in all the racing 911's.
David 23 01-19-2008 11:51 AM
Can you offer any more information on this?
ErVikingo 01-19-2008 12:08 PM
Low oil pressure light on most cars I've either raced or seen. Usually shift lights are in the line of sight of the driver.
Drew001 01-19-2008 12:26 PM
http://homepage.mac.com/drew1/.Pictu...n_RedLight.jpg
Picture courtesy of Plavan from this thread regarding an oil pressure light.
And a Monster shift light like ErVikingo mentioned:
http://performancespares.com.au/images/4299.jpg
porsche930dude 01-19-2008 03:31 PM
how about a cobalt d-pic and a valentine-1 in the same guage
signature65 01-20-2008 11:38 AM
Yup, I was wrong. Sorry guys. Its an oil pressure light.
Danny_Ocean 01-20-2008 11:49 AM
Combo head temp and (2nd) oil temp guage (sender to be installed @ auxillary cooler)
Rick V 01-20-2008 12:30 PM
If I was going to loose my clock it would be nice to replace it with a volt/amp rig. I have ofter wondered why the car didn't come with those from the begining.
porsche930dude 01-20-2008 01:27 PM
probrobly because there pretty much useless to most people
Joe Bob 01-20-2008 02:51 PM
I had Wesstach build me a head temp and battery charge gauge. http://forums.pelicanparts.com/uploa...1200869489.jpg
JohnJL 01-20-2008 03:15 PM
I also used a Westech gauge, this one a 6-way (one for each head) selectable CHT gauge. #4 runs the hottest...
http://forums.pelicanparts.com/uploa...1200870910.jpg
dipso 01-20-2008 05:12 PM
I have mine replaced with a picture of my wife.
Just joking.
A clock telling me what time it is, is better than my wife telling me what time it is.
RSBob 01-20-2008 10:11 PM
combo volt and head temp which mimics the 911 oil press and oil temp gauge.
cab83_750 01-20-2008 10:21 PM
Voltmeter only. Or Voltmeter and A/F Gauge.
