Differences between SWB & LWB. How to make a turbolook SWB
What are the differences of SWB and LWB. What do you need to make a widebody SWB ? Are the rear turbo banana arms bolt on ?
Old 01-22-2008, 10:57 AM
jluetjen's Avatar
Step 1: Put the SWB aside
Step 2: Buy a LWB. The most economical solution would be a '74-'77 since their bigger bumpers will align better with the wide body body-work.
While it is technically feasible to do the conversion that you describe, all that you'll wind up doing is spending a heap of money reducing the value of the SWB car that you've got. If you don't desire the qualities of a SWB's, financially you'll be much further ahead selling your SWB to someone who appreciates them and then using the money you got from the sale to buy a mid-year ('74-'77). You'll still have to do some cutting and welding to change the rear trailing arm mounts, but you'll be far ahead of where you'd be if you started with a SWB chassis.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 01-22-2008, 11:54 AM
304065's Avatar
Agree with John. Not only does flaring the fenders devalue the car, every SWB car I've ever seen has rust, which makes it a poor starting point for the high loads imposed by flared fenders (and the big brakes and engine to go with them). Turbo arms are VERY expensive and they can crack.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 01-22-2008, 12:03 PM
williecoyote's Avatar
+2
Jluetjen and John Cramer speak the truth.
Will
85 carrera
Old 01-22-2008, 12:17 PM
Torsion tubes are different, rear arms are different. Therefore different wheelbase lengths
A lot of money, time and effort.
No Turbo arms are not a bolt-on, you have to replace the torsion tube, not a insignificant, or cheap task
If you already have a SWB and want a wide body, then as suggested sell it and find a better starting candidate.
I would suggest an SC as a basis for a turbo body car.
Robert
Currently Porsche less (but the wife has 2)
Old 01-22-2008, 01:10 PM
Guys i know all this stuff. The car is bought, and it is already a turbo look swb. Lets put the cost issue aside. Can you please help me with this matter ?
There are some other reasons why we chose thios car. It already has a 3.0 engine, and is 965 look.
The car will be made into a 74 rsr replica. The problem is that it has those huge spacers that we need to get rid of. Thats why i ask about arms
Old 01-22-2008, 10:18 PM
haycait911's Avatar
could you post a couple of pics? I'm curious.
Old 01-22-2008, 11:31 PM
300hp 1800lbs is the goal
pksystems's Avatar
My $500 '66 came with FG Turbo look rear, with longhood front (and turbo wing)..
It does look a bit wierd with the huge flares, altho I haven't seen a lwb flared up close. I'm almost wondering if the 2.25" wheel move is that noticeable with the flares....
Anyway, whenever I get around to playing with it I'm gonna try to get the early rear, ducktail, possibly a 915, or 930 tranny, and a 2.0TT motor. Depending on how it handles I might get crazy like MT912RS for the rear suspension and convert to lwb. I haven't started looking too much yet, but yes, you probably have some rust. I know mine does, which is why I'll prolly be adding a full cage minus X-braces, while fixing the rusted panels.
As for moving the wheels farther out..... mine has some pretty horrid looking cragars that look like they belong on a 60's muscle car (polished billet aluminum I think they are). They are pretty light 15x7 and 15x9 running 225 and 295. I think the lip on the rear wheel is like 6+" :P
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 01-23-2008, 01:26 AM
No prob, but why are you curious ?
What is wrong with a SWB turbo look ???
Here goes
Old 01-23-2008, 05:08 AM
pksystems's Avatar
How wide are the spacers? they must be huge with 1990+ offset wheels :P
Old 01-23-2008, 05:22 AM
http://cgi.ebay.com/ebaymotors/1967-911S-Real-but-project-NO-RESERVE_W0QQitemZ120214027348QQihZ002QQcategoryZ10 156QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Here is a 67S w/ turbo flares.......I am sorry this is sacrilege!
63 356 2.1 Rally Coupe
75 911M 2.7 MFI
86 Sports Purpose Carrera "O4"
19 991.2 S
25 992.1 GT3RS
Old 01-23-2008, 05:27 AM
jluetjen's Avatar
a '67S ???!
John
'69 911E
Old 01-23-2008, 05:31 AM
The turbo arms really need to be bolted to a torsion tube that has the mounts in the correct position for the arms, as they have different geometry than the standard arms. They are also designed to put the wheels in the correct place for the longer wheel base. So, you would need to modify your torsion tube mounts to replicate the anti-squat and camber change characteristics inherent in the turbo/RSR geometry, and to locate the pivot points further forward to bring the wheel center where it needs to be, if you want to use the same wheel location. Good luck with this, it won't be easy.
Or, you can just change the rear fenders to match the current wheel locations. You have to change the fenders anyway, if you want it to look like a '74 RSR. Most people wouln't spot the wrong wheelbase.
Or, you can leave it alone and use different wheels, with an offset that solves your problem with the spacers. After all, the turbos still used spacers on the rear and the 74 RSR had much wider wheels anyway.
JR
Old 01-23-2008, 06:08 AM
Is that pic the actual car we're talking about here?? If so, it looks to be an unusually complete conversion. I mean, no front wing windows or rear quarter vent windows. Looks LWB already. Interior looks to be updated. Euro side marker lights and all!!
If that is a conversion(and the actual car your talking about) it's the most complete one I've ever seen and I wouldn't mess with it.
Current: 1975 911S --Chocolate brown
Past:
1967 911S --Bahama Yellow
1990 C2 Targa --Silver
1973 914 2.0 --Delphi Green
Old 01-23-2008, 08:35 AM
Slippery Slope Victim
NY65912's Avatar
Step away from the SWB and put down that cut off tool. NOW!
But then again, if it's your car do whatever you want, but it is true sacrilege!
Mike˛
1985 M491
Old 01-23-2008, 08:43 AM
Guys yes. This is the actual swb car. It is a 66, with a 3,0 sc engine, and steel turbo flares. I dont get it though. Were are the diferences among swb and lwb ? Are all the exterior panels the same ?
Whats the fuss about chopping an already converted car ?
I guess, the only trouble would be the installation of the rear turbo arms.
Old 01-23-2008, 11:07 AM
And also, this is a euro car.
Old 01-23-2008, 11:09 AM
They moved the rear wheels back by a couple of inches. In short, they chages the spring plates, swing arms, axles and the rear fenders. There's other stuff, but that will get you started.
I suppose the fuss has nothing to do with you, as I suspect somebody else converted the car. It's just that a 66 is rare nowdays, so most people would have left it stock and modified something more common. The other thing is that these conversions are seldom done well, or on a sound car, so when you take them apart you find all sorts of problems. Porsches are often shiny on the outside and quite ugly under the skin. They rust.
The installation of the turbo arms requires a huge amount of work to be done correctly and few people are willing to tackle the work. Changing out a torsion tube isn't for the inexperienced. I'd suggest studying the problem a little longer to be sure you want to head down this path.
JR
Old 01-23-2008, 11:49 AM
jluetjen's Avatar
Personally I always find it a bit jarring to see a late 1980's car with 1960's gauges and interior trim in it. It's kind of like walking backstage on a movie set. It looks like the real thing on the outside, but the inside is completely different, or just not there.
John
'69 911E
Old 01-23-2008, 12:26 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
I had a 66 wide body many years ago. No one can tell the difference from the outside. But, to answer your question about installing the turbo trailing arms, you would have to move your rear fender flares back to center over the wheel, which will now be 2 inches further back and that in itself is not worth it considering your car is basically complete.
Old 01-23-2008, 03:09 PM
