dial 911's Avatar
Shortest steering wheel hub
hi this question is for those that are running an aftermarket steering wheel with a hub. my question is which hub brand has the shortest hub? thanks
Old 01-23-2008, 12:32 AM
wblackw9's Avatar
Send a message via AIM to wblackw9 Send a message via Yahoo to wblackw9
Think you will find that they are all a standard size. If anything you would need a spacer behind the wheel so your knuckles dont reat the dash if you have big hands!!
Old 01-23-2008, 12:57 AM
there was a thread a few years ago about the clearance between wheel and dash.
Many guys complained about their aftermarket wheel being too tight. I was surprised that different wheels had different clearances.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 01-23-2008, 05:36 AM
David's Avatar
If you get much shorter than the standard hub with a small dish wheel, you hands will probably hit the turn signal staulk. What wheel do you have?
Old 01-23-2008, 05:42 AM
