makaio
Guest
Posts: n/a
Question Oil return tubes....
I'm in the process of replacing my oil return tubes with the collabsable tubes. I have read the Pelican article on this, but am still having difficulties in getting the tubes to expand. Any advice would be greatly appreciated.
Thanks,
Matt Chamblin
78 911 SC
Old 04-02-2001, 11:12 AM
john walker's workshop
Guest
Posts: n/a
Post
all red seals, with dow-corning 111 silicone paste. lube inside the tube and move it in and out until it slides well. green seals are difficult, black seals are impossible.
Old 04-02-2001, 11:43 AM
Jim T
Guest
Posts: n/a
Post
If your car has the smog pump and air injection system in place, I *think* you are going to have to drop down one of the heat exchangers. One of the quirks of the 78 and 79s.
If you are able to do it with both heat exchangers in place (and you have the pump and air injection lines) let me know, I'd be curious.
Old 04-02-2001, 11:45 AM
Kurt V
Guest
Posts: n/a
Post
We just went through a similar thread about a week ago and now I am worried. I just put the steel OEM tubes in with green seals. Used Dow111 and could expand the tubes with easily! Does this mean possible leaks or am I worrying about nothing. Why were mine so easy and others hard?
Kurt V
72 911E
Old 04-02-2001, 11:47 AM
Leland Pate
Guest
Posts: n/a
Post
Kurt, I'd say that you are just more of a man than Makaio.
Leland Pate
___'99 Dodge Dakota <-which pulls the "real" car
___'79 SC Targa
Which hopefully will be back together soon...
Old 04-02-2001, 11:52 AM
makaio
Guest
Posts: n/a
Thumbs up
Just an update. I purchased some Dow-111 today, and it made it way easy to expand the tube. So Kurt, I don't think you are in trouble. So far I have not had to remove the heat exchangers, but I did have to un-hook the air injection lines to slide the first two tubes in, on the passengers side. Hopefully I will be able to get the other two in, on the drivers side this week.
Thanks for all the help, I wouldn't have been able to do it without your help.
Matt Chamblin
78 911 SC
Old 04-02-2001, 08:18 PM
Guest
Posts: n/a
Post
the driver's side has the clearance problem. don't forget to install the fat tube toward the engine case.
Old 04-03-2001, 08:23 AM
