-   -   Oxygen Sensor Replacement (http://forums.pelicanparts.com/porsche-911-technical-forum/389508-oxygen-sensor-replacement.html)
DRACO A5OG 01-26-2008 11:29 PM
Hey Gents,
I replaced my O2 Sensor Today (BTW, easiest and quickest project ever done, simply jack her up, wheel off, PLACE SAFETY JACK STAND, just need a 22 MM wrench or fully open adjustable wrench, feed through, a small screw driver for the grommet and connect. That's It!) and found in the engine compartment this connector. Actually this is off a member's post.
I noticed his has the plastic housing around the tip of the spade connector. Mine did not. :eek: I think it may have broken off or removed for what ever reason by the PO.
Mine is held on by a bracket then a green wire 3/4 inch long then the spade connector. I did my best to insert it into the new 02 sensor but am worried it may not be connecting. :confused:
She is not showing any negative signs but just wondered if I need to rebuild/replace that yellowish connector and wire.
Any advise would be greatly appreciated:
Part in Question
http://img.photobucket.com/albums/v5...Connection.jpg
My Attempt to Photo Shop what I am talking about:
http://img.photobucket.com/albums/v5...nnection-1.jpg
slodave 01-26-2008 11:36 PM
All I have is a little piece of wire left. That connector broke years ago and I did not want to spend the $$$ on the part.
http://forums.pelicanparts.com/uploa...1201419408.jpg
DRACO A5OG 01-26-2008 11:55 PM
Oh Hey Dave,
Cool, I am going to do something similar, thanks Brother!
3.2 CAB 01-27-2008 11:13 AM
That connector is also used on other German cars, BMW, Mercedes, and of course Porsche. Possibly a lot of others also. They will and do crumble apart from the engine bay heat over the years. Some look just fine, TILL you touch them. Then they fall apart. A very common problem. Many options for remedies. You can be creative. Good luck!! Tony.
DRACO A5OG 01-27-2008 01:33 PM
Going to use a 1/2" Mylar spacer from Home Depot to support the wire and spade so it can be inserted. I will cut a slit down the side to insert the wire and crazy glue it to the yellow harness and wrap with heat resistant electrical tape.
DRACO A5OG 01-30-2008 04:00 PM
Do you gentlemen know the part number or name for that connector?
MBAtarga 01-30-2008 05:04 PM
When I searched for more information on the connector in order to replace mine (cracked), it appeared that it's part of the rear engine harness and is not identified separately.
DRACO A5OG 01-30-2008 05:16 PM
I was afraid of that oh well. I made a replacement/mod part. will post pics on how I did it.
So far from Home Depot 1" & 1/2" Nylon Spacer & Crazy Glued together to meet the same length, you can find them at the specialty drawer.
8 pin male connector rubber sleeve 1/2" diameter from a local electronics store to keep it water tight.
Liquid electrical tap to keep the wire in place
Dremel to cut out 1/8" slot for the wire and notch for the new O2 Sensor to slip lock on to and bevel the edges so it will slip into the new O2 Sensor female connector and slip into the rubber protector sleeve.
Tested it (without the green wire and stab, it is on the car) on the old O2 Sensor, fits perfectly and locks in. Next thing is to install it on the green wire and stab stem.
Boy, I just have too much time on my hands. Actually it took less the 20 mintues to make the part. 5 minutes at the home depot & electronic specialty store each.
slodave 01-30-2008 07:54 PM
5 minutes at Home Depot. BS! No one can get in and out of Home Depot in 5 minutes!
DRACO A5OG 01-30-2008 11:24 PM
Ok 6 Minutes ;). I knew what I was looking for and I bought the liquid electrical tape and went thru the self check out. Seriously, it took me longer to find parking and walk from the space far enough away so no retard will slam their cart on my baby.
Gee it reminds me of a T-shirt I saw back in the day where the guys head was looking at all directions while driving so no one would hit his baby. :eek:
Thrlls 01-31-2008 12:28 AM
Yes, please post some pics of the process.
I was fortunate and was able to fish the broken piece out of the female rubber connector, then super glued it together. However I know in the future I'll be revisiting this thread for your wisdom.
DRACO A5OG 01-31-2008 12:31 AM
Done Just Posted the Thread with pics SmileWavy
http://forums.pelicanparts.com/porsche-911-technical-forum/390248-o2-sensor-connector-crumbled-1300-replacement-part.html
Thrlls 01-31-2008 08:17 AM
http://forums.pelicanparts.com/showthread.php?t=390248
Clever...very clever!
This will save people $$$ big time!
Looks like it'll take a steady hand and some carving skill.
Mahalo Nui Loa! SmileWavy
WI wide body 01-31-2008 10:52 AM
While replacing the Head Temp. Sensor in my '86 Carrera I noticed that the OS cable was nasty looking. I just bought the OS cable that is in the attached pic and it looks to be relatively easy to splice the wires and replace.
Has anyone else done this and what should I look for?
Thx.
Ed Chttp://forums.pelicanparts.com/uploa...1201805517.jpg
Thrlls 01-31-2008 11:52 AM
I just purchased a Bosch Universal OS with longer wiring. I'm installing TRE headers and the OEM OS wire is too short.
This kit includes twist connectors which makes splicing the wires very easy and safe.
I purchased it from a local parts store here, but I have seen it online as well. The kit is complete and easy to do.
DRACO A5OG 01-31-2008 03:21 PM
I was thinking of that connector above but I was concerned why the enginners used so much insulation. I was assuming due to that particular wire being the heating wire for the O2 Sensor.
LWJ 03-27-2010 10:04 AM
A thank you and bump for an excellent thread!
Larry
ertech 03-27-2010 11:21 AM
anyone know the part # for the universal one?
DRACO A5OG 03-27-2010 11:52 AM
O2 Sensor for a Ford Taurus
