Kurt V
Guest
Posts: n/a
Post I forgot where this part goes
Stupid question from someone who should have taken more pics as I took things apart. What does this hose and tube connect to? Thanks
Kurt V
72 911E
Old 03-31-2001, 04:39 PM
mackgoo
Guest
Posts: n/a
Question
What is the part that looks like a bullet made of?
Old 03-31-2001, 05:20 PM
john walker's workshop
Guest
Posts: n/a
Post
drain for the aircleaner. hangs on the back of the oil cooler. the hose to the bottom of the aircleaner.
[This message has been edited by john walker's workshop (edited 03-31-2001).]
Old 03-31-2001, 05:35 PM
Early_S_Man
Guest
Posts: n/a
Kurt,
The drain/vent tube with rubber tip (tip straight down) gets bolted to the top piece (in front of tin, actually outside the engine compartment) of engine tin that arches over the bellhousing, to the right of the starter, by the M6 bolt closest to the transaxle ... the small vent hose goes to the front side of the air cleaner housing.
Warren Hall
1973 911S Targa
[This message has been edited by Early_S_Man (edited 03-31-2001).]
Old 03-31-2001, 05:37 PM
Mrdi
Guest
Posts: n/a
Cool
There's one like that in the ladies' shower at the gym??
Old 03-31-2001, 06:31 PM
feelyx
Guest
Posts: n/a
Post
What are you doing in the ladies shower?
Old 03-31-2001, 07:07 PM
FrdzRed
Guest
Posts: n/a
Post
Looks like Mrdi's busted. Yea what were you doing in the ladie's shower?
Old 04-01-2001, 10:22 AM
Shakenbake
Guest
Posts: n/a
Post
Recently checking for source of oil leak, determined that all oil return tubes are not leaking, source seemed to be coming from this airbox overflow tube or the oil pressure sending unit seal. Noticed that the oil vent tube from the oil tank to air box always seems to be blowing small amounts of oil into the airbox, is this normal? Could a vacuum leak cause this?
Shakenbake (Chris Baker)
1974 911 Coupe
'91 "A" stock champion WV
'90 SCCA FTD
'99 SCCA 3x "A" stock winner
Old 04-01-2001, 05:58 PM
george993
Guest
Posts: n/a
Exclamation
shakenbake,
Thats the vent/overflow tube, check your oil level in the tank you may be overfilling it. Bruce Anderson recommends fill to the half way mark on the oil stick, of course, with the car level and at operating temp.
Old 04-01-2001, 07:22 PM
Early_S_Man
Guest
Posts: n/a
Chris,
You might try cleaning the flame trap where the 25 mm vent line from oil tank goes into the airbox ... cylindrical, 2" long, 1" diameter slip-fit object made of brass, with perforated ends, and coarse shredded metal visible inside. Early 73.5 CIS engines used the same part 901.107.729.00 as earlier carbed and MFI engines.
On early US vehicles with PCV (positive crankcase ventilation) systems, it used to be recommended that the PCV valves be cleaned at every oil change, though that practice has fallen by the wayside over the decades. If your flametrap is dirty or partly clogged, the velocity through it would increase, and the likelihood of oil getting through to the inside of the air box seems probable. Running your oil tank at a level such that at max. normal operating temps (210-220 degrees F) the oil level expands to no higher than midway between the marks on dipstick -- 1 liter below the 'Full' mark ... will minimize oil getting into the airbox!
Warren Hall
1973 911S Targa
Old 04-01-2001, 07:45 PM
DavidH
Guest
Posts: n/a
Post
I am putting things back together and noticed the rubber tip on this cracked. Went to the local dealer to pick one up and he told me that this piece doesn't go on a CIS car, "only for older carbeurated models". Is he nuts???
78 3.0L/3.2L CIS 911SC
Old 04-05-2001, 07:19 PM
Early_S_Man
Guest
Posts: n/a
David,
Yes, he is completely crazy! It was used on carbed, MFI, and CIS cars! Per Volume 3, Section 2, p. 0.1 - 3/1, a picture of the clutch side of CIS engine with said vent tube!
Warren Hall
1973 911S Targa
Old 04-05-2001, 08:22 PM
