Tlook
Guest
Posts: n/a
Question converting to elect.speedo-any hints on wiring?
There are alot of things I didnt think out when putting this 78trans in my 71. Stub axles,clutch cable, and now.....the speedometer. Today I wired the module, and ran the two wires up to where the (newer) speedometer sits. THen I gave up. Can any of you tell me if you've done this conversion, and what it takes.ie.where these two wires go, and if I need hot/ground for any thing special on this speedo guage?????????
Frustrated and wanting to drive.....S in VA
Old 04-04-2001, 06:25 PM
Bo
Guest
Posts: n/a
Post
No input, but since I'm about to do the same thing soon (79 tranny into a 72) I will be most interested in seeing what kind of input you'll get!
You mention "stub axles" - I'm not entirely sure of what you mean by that - drive shafts??
Don't tell me that I TOO have overlooked more things to change...
1972 911S Targa
My project!
Old 04-04-2001, 11:07 PM
Bo
Guest
Posts: n/a
Post
Damn, I'm doing a lot of double-posts today...
[This message has been edited by Bo (edited 04-05-2001).]
Old 04-04-2001, 11:08 PM
john walker's workshop
Guest
Posts: n/a
Post
power with key on to the 12V, ground to -, one wire from sensor to the ground term. the other to 31b. doesn't matter which one. the A term. is for cruise.
[This message has been edited by john walker's workshop (edited 04-05-2001).]
Old 04-05-2001, 12:44 PM
Tlook
Guest
Posts: n/a
Post
Thanks John.........Bo, I did mean drive shafts/axles. I recently found that the distance of the axles w/ c/v's on it is identical, but what is not is that the older axle has 2 shuffle pins and the bolts are VERY LARGE--so, with the 79 trans you will have to use a later style 78+ ? axle. I also upgraded my trailing arms--so the spindles are a match.........if you havent, you will have to at least get some spindles that will work. Also, The nose piece of the 78 trans pinched the lft rear brake line where it T's off !! BEFORE you put the trans in, be shure to unbolt that holding mount and move it towards the rt rear side. You do not want to have to pull everything becuase of that line...beleive me
Old 04-06-2001, 04:53 AM
Bo
Guest
Posts: n/a
Red face
Thanks for your tip on the brake-lines! I'll be sure to make that adjustment *before* trying to install it all.
About the drive-shafts; well, it is just another expense in the long, long line of unexpected expenses - but now that I'm in the middle of it, I can't start cutting corners.
Well, it's only money...
1972 911S Targa
My project!
Old 04-06-2001, 05:12 AM
