911 odometer, need recommendation
Hi, can anyone recommend a good shop that can fix my odometer? I have an 83SC. I know this is a common problem, and would like to find a good repair shop. If anyone has had a good experience with a repair shop let me know. I am in Ma. but I don't care if its local. Thank you.
North Hollywood Speedo does well-recommended work. I'll move this to the main page so you can get a few more responses, maybe there is someone local.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Detached Member
North Hollywood Speedometer for sure. It'll cost you less than $10 to ship it to them. They will repair, calibrate and repaint the dial as well as clean and lube.
Hugh |
i have sent an odometer to North Hollywood Repair. They were prompt & their work was excellent.
Thank you for your help! I will send it out asap!
Thank you!
