Danny_Ocean's Avatar
Must I re-align after doing this?
Just paid an arm/leg today for a 4-wheel alignment, only to remember I have to change the front strut inserts and add the Elephant Racing bump-steer kit (washers/bolt type).
Will I need to re-align after completing these projects?
Old 01-30-2008, 01:51 PM
Friend of Warren
Afraid so. Even if you mark everything I doubt you will get things back into correct alignment.
Kurt V
Old 01-30-2008, 01:53 PM
Southern Class & Sass
Dixie's Avatar
How particular are you?
What I'd do is install the bump steer spacers and have the shop reset front toe only.
(The spacers will only change toe, and only by a touch. New inserts will have a negligible effect. After all, you don't move the alignment plates when you replace shocks.)
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 01-30-2008, 01:57 PM
Not very. I was only planning on having the front-end aligned, but the shop insisted all four wheels must be done. I must rebuild the rear-end (someday), but was concerned about the front end only as I knew it was out-of-whack (steering pulled, tire wear, etc.).
Old 01-30-2008, 02:00 PM
Dixie's Avatar
Do you know what the front toe is currently set at?
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 01-30-2008, 02:02 PM
Yes, the shop gave me a print-out of the settings (before/after).
Old 01-30-2008, 02:11 PM
Dixie's Avatar
And the front settings are...
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 01-30-2008, 02:15 PM
I dunno...paperwork is at my shop. I'll post tomorrow.
Old 01-30-2008, 04:28 PM
Walt Fricke's Avatar
Danny
Don't let the shop BS you into doing the whole thing over. You will not have changed rear alignment or front camber or caster. Just front toe. That can easily be adjusted independently of the rest of the car.
I think the bump steer kit will cause the toe to move out a bit. Ask the shop to adjust the toe by taking equal turns on each toe adjuster until the total toe is back to what it was.
The worst that can happen is your steering wheel will be a little off center when going straight.
If they give you static, find someone else.
Walt Fricke
Old 01-30-2008, 07:05 PM
911_pilot
Porsche Crest steering adjustments and shocks
I am in agreement with Walter. A bump steer kit (spacing washer) did not change the toe settings enough that I could measure it with a tape measure.
The Hunter Laser Alignment did find .03 degree change on drivers and a .01 on the passengers side. I was not able to tell the change in the drivablility. Since this was in range, I left it as is on the '86 Carrera.
Replacing shocks has no affect at all. You are not moving the geometry.
911_pilot
Old 01-31-2008, 03:02 AM
If you're fussy about your alignments make sure they align the car with you in the seat. It can make a huge difference.
Richard Newton
Autocross Performance Handbook
Wheel and Tire Performance Handbook
www.amazon.com/Wheel-Performance-Handbook-Motorbooks-Workshop/dp/0760331448/ref=sr_1_11?ie=UTF8&s=books&qid=1199198539&sr=1-11
Old 01-31-2008, 03:07 AM
abit off center
cgarr's Avatar
Can I ask how much was the 4 wheel alignment? Im thinking we are too cheap
______________________
Craig
G2Performance
Old 01-31-2008, 04:23 AM
shbop's Avatar
Where I am, it's $165.
Jon
Old 01-31-2008, 05:47 AM
3.2 CAB's Avatar
Lifetime alignment service policy for my 750iL, was $140. It is for as long as I own the car. I have been using the same shop for many years. I have all of my cars done there. It has gone up a few $ over the years. It used to cost $99.00 for the four wheel lifetime alignment.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 01-31-2008, 06:52 AM
Well...my shop charges $99/hr. They said it took them awhile because the adjustment bolts (cams?) in the rear were seized and they had to soak & work on them. They did some other work (oil temp sender) and the bill was $569. Nothing is cheap here (SoFla). (I tried a "cheaper" shop previously and they f-ed everything up, so now I pay more, but only for the stuff I can't do myself).
Old 01-31-2008, 07:09 PM
