Hatari
Guest
Posts: n/a
Post Having trouble separating cyls. from case
I'm doing a top end on a 2.4. Got it all the way down to pulling the cylinders by the factory manual's instructions. They're stuck tight and I don't want to damage fins. The manual says lift them off. It said the same about the cam cradles...that translated into prying carefully for a while.
Help will be appreciated. Some shots of the work in process:
http://members.aol.com/Hatari063/rebuild/rebuild1.html
Jack McAllister
Old 04-08-2001, 09:05 AM
john walker's workshop
Guest
Posts: n/a
Post
a rubber hammer is used for working the cylinders loose . a couple bips on the top, a couple on the bottom. repeat until they move. some are stuck pretty good, so have patience.
Old 04-08-2001, 09:09 AM
Hatari
Guest
Posts: n/a
Post
They're off and I did what you suggested. Once they move an 1/8" or so, they freed up.
This board is great for instant help...
Thanks and regards,
Jack McAllister
Old 04-08-2001, 10:34 AM
