How does this shifter work?
How does this work?
It looks like it only goes forward and back. Am I asking to be flamed here?
Jim 911 Mint Green "RSC" #mintgrun 911 Gentlemen's Rallye 85 Carrera GP White 2012 C63 AMG Mars Red |
sequential transmission just like a motorbike
Peter '13 981S '73 911T '05 996 4S cab, now gone '70 911S Targa, now gone |
Navin Johnson
It is the gear selector for a sequential box. That bicycle brake looking lever on the side is to engage reverse. Pressure from you pulling or pushing on the shifter causes the clutch to disengage and the gear to be changed Pull back= upshift push forward =downshift
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
The Puff.
So it's like those automatics with the tiptronic selectors?
Not at all.
An automatic with "Tiptronic" buttons is just a regular old slushbox automatic, that is having its shifts triggered by the buttons. Like on an old automatic, where you could move the lever from D to 3, 2, or 1. "Tiptronic" is doing the same thing, but the signal is being sent to the automatic transmission electrically instead of mechanically. "Tiptronic" is just a fancy name and marketing gimmick. A sequential shift trans is a manual transmission being shifted "sequentially" like a motorcycle's transmission. |
Thanks! great info.
I think NHRA pro stock cars use something similar.
2000 Boxster S 1984 Carrera 1976 912E |
