I did notice the Red LEDs are a Deeper Red and very intense compared to White Bulbs |
I fabricated my own, mounted it inside the back glass. (click link below to see)
It sure can't hurt! |
I have not only the OEM interior CHMSL on an '83 SC but a pair of motorcycle LED brakelights that are mounted on the underside of the rear wing. They are totally self-contained (battery-operated, no wiring) and activate super-instantly through a mercury switch. Very bright, and they flash in a rapidly jittering pattern.
You only have to have been rear-ended once. Destroyed our first Boxster. |
i'm doing the 993 style brake light/roof spoiler,dont take any chances,i would hate to be a hood ornament on a tractor trailer
Safety first....and you got option...
http://forums.pelicanparts.com/uploa...1202486453.jpg http://forums.pelicanparts.com/uploa...1202486498.jpg http://forums.pelicanparts.com/uploa...1202486570.jpg |
While I think the safety aspect of the third brake light has been diluted with over 22 years of use (when they first came out...everyone noticed), I think having some nuclear-bomb-bright LEDs would do the trick. Whatever it takes to get people to wake up behind the wheel. IMHO, way too many cars have too many driver aids that "unplug" people from the fact that they're in control of a 3500lbs chuck of metal.
I have an '85 Targa as well and installed a high mounted inside one several years ago. Easy installation and gives me a bit more peace of mind that I'm a little more visible than before.
Here are a couple of threads on the install: http://forums.pelicanparts.com/porsche-911-technical-forum/97229-wiring-3rd-brake-light.html?referrerid=5978 http://forums.pelicanparts.com/porsche-911-technical-forum/106190-how-3rd-brake-light-install.html?referrerid=5978 Next for me is installing a rear red fog lamp, though I have to figure out how to wire it. As far as I can tell, my '85 does NOT have the wire harness tucked up inside the bumper. |
I am leaning towards the Pilot because of it's 1" profile design and being mount high off the rear window glass, the slight glow will double as a BLS malfunction warning system
Or drill a hole in the OEM interior to function the same way, but the the OEM has more obstruction in the window. ??? |
Do you have a pic? |
Hey, if it reduces the chance of some idiot in a pickup taking out your rear decklid by 50%, it's a good thing. Roads are full of idiots that can't drive and don't pay attention, and short of living in Montana or never driving, it's darn near impossible to avoid them.
Any Light is a good light as long is its not a ricer one under your'e car,every day the number of 16 years olds getting their licenses goes up so our chances of survival go down....sorry im a little bit negative today
Some one nailed it above - third brake lights are expected to be seen on all cars these days.
If one doesn't come on, then keep that SUV floored while talking on the cell phone, while slapping down the kids, painting her nails, and sipping her latte. When 3rd brake lights first came out, they reduced rear enders by 33%. I put a LED bar in mine for extra insurance - its black housing blends nicely with the black rear parcel shelf and is easily reversible. I would rather sacrifice looks and originality for several thousand dollars in body work or a complete total loss, but since you are asking the question, it sounds like you are already on the right track. P.S. I put it on the parcel shelf because it did not block my rear vision like mounting it at the top of the glass - I tried it that way first and didn't like it when I need a clear view as far back as possible to see local law enforcement. |
I did the 18.5" Pilot one. The biggest problem was getting the epoxy to finally stick to the glass for the holders. Up top you can't see it from the rear view mirror, and its barely visible from the exterior until you hit the brakes. Yes, it does help alot. As someone said, people expect to see a 3rd brake light. It cut down on people almost rear ending me alot.
On OEM high mounted interior housing (eg 1986 model), is the light bulb socket positioned such that the above main LED cluster points rearward? |
never
| All times are GMT -8. The time now is 07:16 AM. |
