Guest
Posts: n/a
I am looking for a fresh speaker for the dash of my 69 911E. I am going to keep the stock radio for now, but would like to find a new speaker. It seems like an odd size at 4x9, and I can't seem to find it listed in the Crutchfield catalog. Go figure.
Any ideas? Thanks, Ron |
Guest
Posts: n/a
I am pretty sure Blaupunkt do direct replacements. Check www.blaupunkt.com
------------------ Phil Garner '72 911E Sporto |
Guest
Posts: n/a
Ron,
I put two JBL 3.5's in my center speaker hole of my 73. I constructed a small mount out of sheet aluminum to hold the speakers. They sound pretty good. http://www.geocities.com/william_armentrout/head_unit.html Check out www.crutchfield.com for a stock replacement. If they don't have one, I don't know who would. Bill ------------------ William Armentrout 1973 911T 2.7 carerra rs specs www.geocities.com/william_armentrout |
Guest
Posts: n/a
Yep, it is a weird size and although I didn't look too hard, I didn't find any direct replacements. Similar to Bill's approach, I put a 4x6" coax Blaupunkt there, and cut a little plywood filler plate to cover the remaining opening. (This is a test fitting before I cleaned it up better and painted it black.) Works very well.
Guest
Posts: n/a
I have a 70 911T which I just replaced the speaker on the center dash. I actually went to a local Wal Mart & bought a single Pioneer speaker. The fitment was for a broad range of European models. In any event it fits good but not perfect. I can screw down two of the holes but not all four of them. At least it's not moving. This may be a good solution if you're on a budget or just needed a speaker like I did. Most of the time my stereo is off anyway.
Author of "101 Projects"
Anyone figure out a source for the 4x9 speakers?
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Thread Tools | |
Rate This Thread | |
