Basic fuse box info on 911SC
I have an extremely basic question but I've searched the forum here and can't seem to find an answer. I have a 1981 SC and I'd like to try replacing the fuse to see if that is the reason my fog lights won't work (I've already tried replacing the bulbs).
I found this diagram already posted:
http://pelicanparts.com/911/911_Parts/Electrical/911_electrical_82SC_fog.jpg
I'm sure that is probably enough for most people, but I'm afraid I look at this diagram and have no idea which fuse is which when I look at the box. Is there a picture or basic info on which fuse is which and the basics of how to replace a fuse?
Old 02-10-2008, 12:08 PM
Just looked at my 1983 cab fuse box cover & it shows the fuse the furthest forward is for the fog lights.
1983 911 SC Cabriolet
1999 Durango SLT
20001 Intrepid ES
Dave
Old 02-10-2008, 12:15 PM
Thanks!
Old 02-10-2008, 12:30 PM
burgermeister's Avatar
Mine is also the fuse furthest forward. Also, the fog lights don't work if the headlights are not on and the ignition is not on.
My fog light fuse tends to blow frequently for no apparent reason ... so I have an intermittent short to chase down someday.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 02-10-2008, 01:15 PM
81turboporsche's Avatar
Send a message via AIM to 81turboporsche
does anyone know what size buss fuse goes in their?,if you look at the plastic fuse cover it shows which fuse powers what
1981 911sc Coupe "Valerie" Widebody
2001 Audi S4 Avant, "The Daily Booster!"
2001 Ducati 748 Biposto "The Torture Rack"
71 Chevrolet Corvette Roadster " The Moth Ball"
Old 04-19-2008, 08:36 AM
Somatic Negative Optimist
Gunter's Avatar
Welcome.
I recommend the Bentley SC Repair Manual, lot's of good info.
The plastic cover on the fuse box has a listing inside; 16A fuse.
To avoid corrosion of the fuses, use the special electrical lube that comes in a spray can.
Keep in mind that the fog lights only work with head lights and ignition on.
The fog lights also have a relay (The second one from the front) and they switch on and off automatically between HI/LOW beam.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 04-19-2008, 11:36 AM
thank you very much gunter
Old 04-19-2008, 01:15 PM
