coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
Do I have to upgrade the mc with my new front calipers?
Probably a quick question for Bill, and I did do a search but can not find the correct answer to this one!
I have upgraded to 944T front calipers on my SC and retained the normal SC rear calipers for now. But I am unsure as to if the stock m/c on the SC is adequate for this set-up or if it needs to be replaced for a larger one, or do I need a biasing valve in the system?
Thank you for your help and advice...
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 05-19-2008, 12:30 AM
Bill Verburg's Avatar
You have several problems
1) the caliper is too big for the rotor(I'm assuming you have a Carrera 24x282mm rotor), you need at least a 28x298mm rotor)
2)you have way too much front bias, you need either wide Carrera rear calipers or 964 rear calipers.
3)m/c will need to be changed after the above is rectified
Bill Verburg
Old 05-19-2008, 04:59 AM
