2ndTARGA's Avatar
Spring Plate Adjuster Range Quickie (I hope)
My lowering project is still going well - (see http://forums.pelicanparts.com/porsche-911-technical-forum/390523-finally-going-lower-gut-check.html#post3743790 if you're curious)
Going well, that is after a few big interruptions (leaking output shaft seal, balls falling out of CV joint, discovery of 30 year-old factory brake hoses, caliper rebuilds - stuff like that)
Anyway, I've just done a lot of searching on the many dozens of lowering threads and couldn't find a clear answer to this:
Roughly how much range (ie +/- vertical height at the fender lip) adjustment can you get just from the eccentric adjusters? Now that I've centered mine and am about to finish indexing the T-bars based on angle calculations, etc, I'd like to know how close it needs to be to be in range of the eccentrics when I get it back on the ground.
Thanks,
Ron
1996 993 Coupe, Tiptronic, Polar Silver
1973 914 1.7 Marathon Blue Metallic - Sold
1977 911S Targa - Sahara Diamond Metallic - Sold
1975 911S Targa - Copper Brown Metallic - Sold
Old 02-14-2008, 11:01 AM
I seem to recall that if you have it centered, you should have a little over 1/2" each way, maybe a wee bit more. Someone else will probably chime in with a more "accurate" answer.
Old 02-14-2008, 11:07 AM
