D911_MEE
Guest
Posts: n/a
Post quick fuchs question
is it safe to use wheel cleaner on my fuchs??
it is the non acid type of cleaner but it does say on the tin wipe of any over spil on non wheel areas immediately
any previous experience??
mike 87 coupe'
Old 04-15-2001, 02:34 PM
pwd72s
Guest
Posts: n/a
Post
You didn't specify brand, but does the label claim it is safe to use on anodized surfaces? If not, I'd be cautious. When working with cleaners or abrasives on my car I use the rule of thumb of starting with the absolutely gentlest material I can start with, and only if it doesn't work will I move up on the harshness scale. That's anywhere on the car, not just the wheels.
Old 04-15-2001, 02:57 PM
D911_MEE
Guest
Posts: n/a
Post
its duco wheel cleaner for alloy> steel> plastic
'removes brakedust, ingrained dirt, salt & grease in seconds!' i quote
mike 87 coupe'
Old 04-15-2001, 03:03 PM
Nickshu
Guest
Posts: n/a
Cool
After you are done cleaning them, coat them with vaseline (apply everywhere and then buff it with a soft cloth to remove all the excess). Believe it or not, if you look in your owner's manual, this is recommended every three months. This will keep the dust/grit from sticking to them, and make them shiny again.
Nick.
_ _ __ _ _
Nick Shumaker
1982 911SC Coupe
nickshu@yahoo.com
PCA -- Rocky Mtn. Region
Old 04-15-2001, 03:56 PM
