French Import
zippy_gg's Avatar
About to install Rebel Racing front bushings...
I'll first install the crossmember and A arms by themselves to ensure everything is co-linear.
Then I will need to install the T-bards and and wondering what is the angle between the A arm and the cross member (A and B) should be at a starting point. The car is a cab and I am shooting for Euro height.
The first pic shows the "before", but the sway bar was still in place, and many new parts are replacing the old so I didn't take any measurements.
And here is new shiny stuff, some was powder coated and some has been painted since the pic was taken...
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 12-21-2014, 09:05 PM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Not sure if the starting angle will be an issue. I usually use a jack to get the height close and then put the rear cap and screw on the torsion bar end...if that makes any sense.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 12-22-2014, 06:30 AM
What Kemo said. Measure hub center to fender lip at say 13", and hold that position with a jack. Then insert your adjusting lever in the center of its range and add the adjusting bolt. Put the wheel on and put the car on the ground. Bounce on the center a few times, then measure your height by the means you have chosen. You can probably get an inch or two of adjustment. You should roll the car back and forth a few feet because the wheels can't slip when static. If you are not in range, jack that wheel up a little and re-index the adjustment lever by one notch and repeat. Each front adjustment will also affect the same side and opposite side rear ans well as toe and camber.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 12-22-2014, 08:06 AM
French Import
zippy_gg's Avatar
I don't have the hubs on yet, in fact I am still in the process of installing the A arms with no load. Everything else in on the bench waiting to be assembled.
Then I thought the next step was to install the TBs and clock the arms at a certain angle, add the struts and button everything up.
I just want to make sure I am on the right track.
Thanks for the tip on the 13", as I was looking for a starting point.
Gilles & Kathy
Old 12-22-2014, 10:17 AM
I started at 13" and it was too low. You might start at 14", but it's really only a starting point.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 12-22-2014, 12:56 PM
French Import
zippy_gg's Avatar
Good luck,
Dave
Thanks Dave!
Gilles & Kathy
Old 12-22-2014, 01:59 PM
French Import
zippy_gg's Avatar
A-arms in place with the Rebel Racing bushings.
Driver side has front bracket and cross-member already torqued and arm falls almost on its own weight. Success. Yes I will re-torque once the car is on the ground.
Good side
Passenger side, the A-arm falls easily when putting a 5 lbs weight in the ball joint but gets really stiff when get close to final torque. I tried adding washers and get the same results.
I then tried using the spherical washers, following Rebel Racing's instructions, and it is actually worse when I either properly torque the cross member or the front bracket...
Bad side
Any advice on the next step for the "bad" side?
I am so close and wanted to have wheels on the ground by the end of the weekend.
Gilles & Kathy
Old 01-03-2015, 03:08 PM
Vintage Motorsport
RichardNew's Avatar
I'm thinking of putting the Rebel bushings on my '73.5. Elephant uses grease and that's not a good thing. Grease and dirt create a nice girding paste. Rebel seems to be a better choice here.
Actually I think rubber bushings would work just fine for a street car. Does Porsche even service these bushings any longer?
Don't talk to me about poly either. I know Poly is junk.
Richard Newton
Historic Racing Images
Old 01-03-2015, 04:15 PM
Max Sluiter
Flieger's Avatar
Good side
Bad side
Did you turn the front mount upside down with the washers?
Old 01-03-2015, 05:22 PM
French Import
zippy_gg's Avatar
Yes Max, I did when I tried the spherical washers, and turn it around again when I re-installed with no washers at all (side up is up).
The arm does not move when I put a 5 lbs weight on the ball joint, nor with 10 lbs but then a little push will make it fall.
I suspect I am not too far off but...
The arm moves fine until I get to about 85% torque.
Gilles & Kathy
Old 01-03-2015, 05:26 PM
Max Sluiter
Flieger's Avatar
I guess some shims are in order.
Old 01-03-2015, 05:35 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+1, this will help.
'85 Carrera Targa
PCA/POC
Old 01-03-2015, 05:44 PM
French Import
zippy_gg's Avatar
I tried shimming but the issue remained...
Scratching my head but will resume efforts tomorrow. So many ways to skin a cat!
Gilles & Kathy
Old 01-03-2015, 06:08 PM
Hi Zippy,
It sounds like your front and rear bushings are not co-linear on the PS. They could be parallel at different levels, or at the same level but at different angles, or both. The spherical washers may self adjust to a degree, but if the bushings are at different levels that may actually make it worse. I would try spherical washers, plus a shim in front or rear and see where the shim gives best results. Move the TA around a bit to let the sphericals seat themselves, before tightening.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 01-03-2015, 07:28 PM
French Import
zippy_gg's Avatar
Dave, you brought a question to my mind: is it OK to shim the rear (cross-member)?
As I wasn't sure I haven't tried that yet.
The other question I have: If I use the spherical washers on one side, do I need to do the same on the other side even if it is currently fine?
Gilles & Kathy
Old 01-03-2015, 08:28 PM
Max Sluiter
Flieger's Avatar
Only use the shims when necessary. I think it is easier to shim the front but there isn't any reason you can't shim the back.
Old 01-03-2015, 08:40 PM
French Import
zippy_gg's Avatar
Thanks Max!
I am still learning about best practices on this car...
Gilles & Kathy
Old 01-03-2015, 08:59 PM
French Import
zippy_gg's Avatar
Just a sanity check... The Service Manual indicates a torque of 47 Nm or 35 ft-lb for the front brackets bolts.
Rebel Racing doe not indicate any values at all so I am assuming I should use the "stock" torque indicated in the service manual.
Anyone aware of different torque values?
Gilles & Kathy
Old 01-04-2015, 12:39 PM
DRACO A5OG's Avatar
Oui, that is correct! 47nM
'85 Carrera Targa
PCA/POC
Old 01-04-2015, 12:44 PM
Might I suggest this thread:
Rebel Racing RSR Bushing (Front) A-Arm Install Question
Old 01-04-2015, 12:51 PM
