What?
Eric Hahl's Avatar
How to separate 915 trans from 3.2?
Hi all,
I dropped the engine/transmission on my 85 3.2 last Saturday to replace the clutch and fix some leaks, etc. I'm having a hard time separating the trans from the engine. Are there any tricks to this? I seem to be able to get it separated about 1" and then nothing, it just won't budge. What am I missing?
________________________________________
Eric Hahl
85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD)
2015 981 Cayman S (Sold)
23 Outback Wilderness & 23 BMW R1250GS
Old 02-21-2008, 06:04 AM
74 911Ebay
Trying to remember when I separated my 3.0l and 915 and recall a similar problem. Seems to me I had to unhook the arm the connects the clutch cable to the throwout barring. If I remember correctly the "throwout barring arm" (??) is connected to the transmission and the throwout barring is connected to the flywheel. I think if you push the arm parallel to the flywheel deeper into the bell housing, that releases the spring clip from the ball on the transmission and you are good to go!
But, that was a couple of years ago that I did this, your millage may vary.
Doug
Old 02-21-2008, 07:24 AM
remove the short release arm below the bellhousing first.
206 637 4071
Old 02-21-2008, 08:10 AM
What?
Eric Hahl's Avatar
Thanks guys,
John, are you talking about the short adjusting lever or the longer release lever? I have the short lever removed and still nothing.
Eric Hahl
Old 02-21-2008, 12:44 PM
then pop the long lever toward the end of the trans. the one with the big C shaped spring on it. big screwdriver.
206 637 4071
Old 02-21-2008, 12:51 PM
What?
Eric Hahl's Avatar
Hmmm, me thinks I need a larger lever. Thanks, I'll give it a try this evening.
Eric Hahl
Old 02-21-2008, 12:56 PM
What?
Eric Hahl's Avatar
Thanks John, I just needed a little more leverage to pop it forward. It came off with ease then.
Eric Hahl
Old 02-21-2008, 04:44 PM
