Richard Burns's Avatar
Electrical Problems?
I am having intermittent problems with my '77 Carrera.On some occasions it will not start, (turns over but will not fire). at other times the electric windows will not operate, when I am having these problems the car also develops a miss at about 4000rpm.When all the electrics are operating properly the miss at 4000rpm disappears. One auto elec has suggested that the ignition switch is playing up. What are the thoughts you guys out there? HELP.
Life is not a journey to the grave with a pretty and well preserved body but to skid in sideways, used and worn out saying " What a trip!
Old 02-23-2008, 07:52 PM
Max Sluiter
Flieger's Avatar
Check the easy things first- corrosion on the battery terminals, bad grounds (may take a while due to the number around the car), corrosion on fuse contacts, etc. If that does not work, maybe cracked wire insulation?
Electrical faults, especially wandering/intermitent ones take a lot of time, looking, and testing work.
Best of luck.
Old 02-23-2008, 08:56 PM
fred cook's Avatar
Gremlins............
Check the fuel pump relay fuse for proper seating and connectivity. If the fp is not getting proper power it will cause many of your symptoms. The windows are probably a second issue. If you find that the fuel pump relay fuse socket is discolored or distorted from heat then you are probably on the right track. Good luck with your project!
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 02-24-2008, 04:52 AM
