joseph222's Avatar
Send a message via Yahoo to joseph222
Simple heater backdate question
I'm backdating my 89 Carrera that has factory HE's.
I have read all the threads, but none that I have found categorically state if the left side heater duct that Pelican sells (see pic), allows ample room to clear the larger sized distributor of the 3.2.
If it doesn't, is it a matter of re-shaping it just a bit (hammering), or will it require cutting and welding as I have seen some of the others require?
Also looking for the flexible hose for the left side to connect the duct with the connection that protrudes thru the engine tin from the HE. I'd prefer to purchase this from Pelican also. Anyone happen to know which of the various hoses is the one that would work for this application?
Many Thanks.
Joseph
89 Silver Anniversary Carrera, "Pearl"
Not forgotten... 69 911E ~ 75 914-4 ~ 88 GP White Carrera
Old 02-26-2008, 03:48 PM
I think it's all covered in this thread...I can't tell if that is the 930 left side hot air duct from this angle, but Pelican has them, and it's what I used along with hose sourced from Pelican also.
Gratuitous pics of Carrera heater backdate...
Old 02-26-2008, 04:23 PM
Joseph, I understand your confusion. I looked in the Pelican catalog, and the Left Hand Air Duct (that you pictured above) is not the same one that I purchased several years ago. I "think" mine was an OEM 930 part, and it was significantly more than the one listed (like around $170 if I recall). From that picture, I can see why you question the clearance.
ps: compare that one, with the one pictured in the thread I linked to, and they're not even close .
Old 02-26-2008, 04:38 PM
joseph222's Avatar
Thanks KC -
So does anyone know if this left side heater duct that Pelican sells just requires a bit of re-shaping, or will it need to be cut & welded?
Joseph
Old 02-26-2008, 04:50 PM
Dixie Region R Gruppe
w21055's Avatar
You can tap it in and it will clear.
Instagram @phillipkj4
1980 911 SC Backdated Viper Green
1992 Ferrari 348TB
Old 02-26-2008, 04:58 PM
Virginia Rocks!
VaSteve's Avatar
I had to do some significant banging on mine to make it fit. Get a propane torch, heat it up and wait away. If you don't it will make the distributor cap cockeyed and the car won't run properly.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 02-26-2008, 05:08 PM
X2. If I did this again I'd hold out for the OEM 930 duct.
Old 02-26-2008, 05:16 PM
w21055's Avatar
I agree, I broke a sparkplug wire during the process as well so it wound up costing as much as the 930 duct.
1992 Ferrari 348TB
Old 02-26-2008, 05:17 PM
joseph222's Avatar
Dang! I'm glad I asked!
Hmmm... not sure where I turn to now.
Joseph
Old 02-26-2008, 06:07 PM
Friend of Warren
Not a big deal to massage at all. I used the standard early 911 left side duct. Got a marking pencil and worked out where it needed to be bent in. Heated it up and using the round end of a ball peen hammer, hammered it into shape. Took all of 10 minutes start to finish. Some black paint and finished.
Kurt V
Old 02-26-2008, 06:09 PM
Dumb question I know - why do you backdate the heater?
Early Car Dave
1972 911T/S MFI Survivor
Old 02-26-2008, 06:24 PM
Friend of Warren
Early Car Dave
To get rid of the stock exhaust and go with headers or SSI's
Kurt V
Old 02-26-2008, 06:38 PM
...also to get rid of all that heater junk. Hoses, motor, ducts over the top of the engine...
That's why I did it.
and the heater works pretty well as is. If driving a steady speed, you have to turn it off.
Old 02-26-2008, 06:43 PM
I checked my old orders and here's the 930 part # that I ordered from Pelican ($180 back then): OEM-93010632102.
Put that part # into the search, and you should pull up this page:
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=911M&section=ENGmis&page=4&bookmark=21&part_number=930-106-321-02-OEM
Old 02-27-2008, 05:01 AM
joseph222's Avatar
Keith - thanks for helping to identify my options.
For the price difference of 120.00, I think I'll do a bit of "re-shaping". Maybe I can post some before & after pics.
Joseph
Old 02-27-2008, 10:22 AM
cnielsen's Avatar
I cut out the desired portion of mine and welded in a bent/curved piece of metal. Worked well, looks clean and cost me nothing.
'67 911S
'69 911S,
'70 911ST
'73 911T Targa Signal Yellow
'78 911SC backdate
Old 02-27-2008, 10:38 AM
I have the one pictured in the first post. It will require "reshaping." Torch, beer, and a BFH work well at reshaping it. You really need to pound the ish out of it though.
-Scott
Old 02-27-2008, 10:45 AM
joseph222's Avatar
cnielsen - that looks really nice. I might need to do that. Thanks.
Joseph
Old 02-27-2008, 12:53 PM
Thrasher's Avatar
I'm sure this has been covered, but is the right side duct required on the 3.2's to backdate? I really only want to get rid of that hulking ductwork and fan assembly for better access.
There is a certain dismantler selling these as a pair at a pretty good discount to Pelican's combined prices. But, if you only buy one, Wayne's within $5. Are the dismantler's pieces the same (they look it) or are they different? I'm hesitant to post a link to this "heavenly" dismantler's site on PP out of respect.
'84 Carrera Coupe - B&B Headers and one-out muffler; K&N Cone intake; Steve Wong Chip; Euro height and corner balanced; 171K Miles (9/12)
Old 02-27-2008, 02:06 PM
Originally Posted by Thrasher View Post
I'm sure this has been covered, but is the right side duct required on the 3.2's to backdate?.
No. If you look at the 3rd picture in the thread I linked to above, you can see the left side air duct and hose I used, and that's all you need to connect to the heat tube that sticks up through the rear engine tin. No change to the right side.
Old 02-27-2008, 04:01 PM
