tangerine911S's Avatar
Tire Size Picture Comparison Thread
Tires need replacing and Im not crazy about the size still on the car from the PO. They are 205/55-15's. Im looking to fill out the wheel wells with a larger diameter tire between what it is now and the large OE 185/70 VR15's. I know I may need to lower it a bit but I'm still looking for something a little larger.
What I would love to see are some pictures of different size tires on wheels. Im particulary interested in 15 inch wheel and 195-205/55-65 sizes but maybe this can be a reference for others as well.
I know someone is going to tell me to do a search but I searched long and hard and couldnt find what I was looking for (visuals). If I missed some good info or pictures please direct me to them.
Here is my '72S with the 205/55's that I am looking to replace. Maybe with 195/65 ???? Lets see some pics please!
Brian
Old 02-26-2008, 11:08 PM
lateforlunch's Avatar
squatted a little bit with a set of 205/55's looks real nice. I used to have a customer with a '70 911 S that had his setup like that. I wish I had pictures to share of it.
find someone to re-index those torsion bars and make that car look good! nice car man, it looks red in the pic... is it? Tangerine is pretty awesome too.
Old 02-26-2008, 11:21 PM
Hester's Avatar
I just put 195/65's on the front and 205/65's on the rear of my 1970. I used this cool wheel/tire calculator to figure out what size to use:
http://www.wheelsmaster.com/rt_specs.jsp
Check this out: Hester
Hester
Your car is beautiful, by the way.
Donald
70 S Coupe
03 SLK
01 FXDX
05 Police Interceptor
Old 02-27-2008, 12:43 AM
Tree-Hugging Member
Jim727's Avatar
205/60 front on 15x6; 215/60 rear on 15x7R
Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners.
Old 02-27-2008, 01:46 AM
304065's Avatar
205-60R-15 Pirelli-- ride height has a lot to do with it. But ride height must not be set at the sacrifice of corner balance or geometry.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-27-2008, 04:06 AM
Thanks for the pics. My concern about 205's is that the sidewalls bulge on my 6" wheels so thats why I was thinking 195's.
Hester: Putting 195/65 in front and 205/60 in rear makes the front tire diameter bigger than the back (.75 cm i think). Is it odd to have such a combination? Do you have a profile picture to compare them?
Heres a pic of 195/65's all around and I really like it! 205/60 are slightly smaller diamerter but too pudgy? Opinions? I also love the ride height.
Brian
Old 02-27-2008, 09:12 AM
Tree-Hugging Member
Jim727's Avatar
A 6" rim is within spec for a 205/60 tire.
http://www.tirerack.com/tires/Spec.jsp?make=Pirelli&model=P6000&partnum=06HR56000&vehicleSearch=false&fromCompare1=yes&place=2
http://www.tirerack.com/tires/Spec.jsp?make=Yokohama&model=AVS+ES100&partnum=06HR5ES100&vehicleSearch=false&fromCompare1=yes&place=1
The 195/65 should be slightly closer in revolutions per mile to the 185/70 the car would originally have had.
Old 02-27-2008, 10:04 AM
Hester's Avatar
I don't have a profile picture but I'll work on getting one.
I used "195/65's on the front and 205/65's on the rear" (not 205/60). The circumference of the rear tire is 1.6 inches greater than the circumference of the front tire.
I have 205/60/13's on the 5 inch wheels on my CVCC. They bulge ridiculously! Hester has the 7 inch 911R wheels so the 205's are fine. The sidewall is pretty straight. 195's all around might work well for you. I think the idea is to keep the section width of the tire close to the wheel width.
Grady Clay suggested using a slightly wider tire in the rear to compensate for the 911's tendency for oversteer so that's what I did. I was coming off the freeway once when I had the 18 year-old 185/70's on, the LSD floated the rear, and the back end stepped way out. I countersteered like I was one of the Duke boys and got her back in line. That was a real wake up to 911 oversteer.
Donald
70 S Coupe
03 SLK
01 FXDX
Old 02-28-2008, 06:05 PM
Thanks for the good infro Hester. 195/65 front and 205/65 rear is definately a possibility. I was considering geting some 7" or maybe 7R wheels for the rear so that tire would fit well should I decide to sooner rather than later.
I have yet to experience the dreaded 911 oversteer. Ive never driven one on a track and dont drive agressively enough on the street I guess. Im sure its scary if you dont see it coming.
By the way Hester, you have a beautiful car and a great story so good luck with it.
Old 02-28-2008, 09:27 PM
Skunk works
JV911SYDNEY's Avatar
205/60 15 all 'round on mine
the car has since had new suspension and lowered
964 RS-4
Old 02-28-2008, 09:32 PM
cycling has-been
bkreigsr's Avatar
NLA Yoko 195/60-15's on 15x7
Bill K
Old 02-29-2008, 07:21 AM
195's on 15x7's looks nice! I assumed everyone ran 205 at least
Old 02-29-2008, 07:53 AM
cycling has-been
bkreigsr's Avatar
thanks
since the 195's are nla, I've switched to 205/55 on 16x6's
Bill K
Old 02-29-2008, 08:14 AM
