How do I fix this ?
Hi all,
A couple of weeks ago I wrote about the random blowing of the electric window fuse on my 87 Carrera. I finally was able to do some testing as suggested and in fact it does prove to be where the wire loom goes into the door. If I open the driver door to the stop, the fuse blows. Obviously a short there.
My question is...Is door removal required to get this fixed or is there some way to pull slack into the cabin or door to fix the problem?
Jim T.
87 911 Carrera
Guards Red Coupe
Cat Bypass, SW Chip, 7's & 9's
Old 03-01-2008, 11:14 AM
UnRegistered User
billybek's Avatar
Should be able to access the door wiring by removing the door panel.
Removing the door shouldn't be required.
Look for the obvious but be prepared to have a good look around.
Pull the battery post while snooping around.
Good luck! Let us know how it worked out.
Bill K.
Old 03-01-2008, 11:38 AM
ianc's Avatar
Common problem. My door speaker wires did the same thing. I was able to fabricate a new harness section and thread it through without removing the door, but it was a whore, and plenty of choice epithets were employed. I did need someone to give me a hand with it. Drink 3 beers to get in the right frame of mind, make sure someone's around to help you, get a couple of coat hangers and twine and set to. Good luck,
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 03-01-2008, 12:13 PM
Thanks guys, I will have to it right now. First I have to find a thread on how to remove the (I believe aftermarket) speakers. They are Boston Acoustics and for the life of me, I cant figure out how to get the grills off.
Jim T.
87 911 Carrera
Guards Red Coupe
Old 03-01-2008, 12:46 PM
the wires break and/or the metal core shows through the covering right where the loom bends between door and cowl. even the loom covering cracks, and you can often see the wire problem right there.
206 637 4071
Old 03-01-2008, 12:53 PM
Alii&Maui
Jesset100's Avatar
My guess is that the grill is attached to the door panel and the speaker is attached to the door frame probably like my SC's speaker. Before you start yanking wires take pictures especially the window switches.
1982 SC Coupe
SCWDP#0087
KCSSL#0082
Old 03-01-2008, 01:14 PM
Registered Cruiser
jorian's Avatar
I had the same issue. Took the car to a stereo shop and they managed to fix the harness and thread it back through. Installer said 911's are one of the tougher installs.
87' Carmine Red Carrera - Keeper
82' Silver SC - Sold 79' Gran Prix White SC - Sold
05' Black C2S - Daily driver
I have never really completely understood anything.
Old 03-01-2008, 01:37 PM
Okay, Done!
The door has to come off or you will be there all frickin day.
First of all, the speakers were nuts. I had to pry the grill out of the frame as the mounting screws were behind them. No problem though as I believe they were designed that way. Gotta love Boston speakers.
After the panel was off, I quickly realized that there was no way I was going to get that frayed wire fixed without major time. SO, I pulled the pins on the door hinges and slid the door out a few inches. Bingo, there was the short. Easy to find and even easier to fix. It's back together and working perfectly.
Thanks for the help guys.
Jim T.
87 911 Carrera
Guards Red Coupe
Old 03-01-2008, 02:34 PM
dshepp806's Avatar
Amen to that,..here's something I've yet to address (sounds quite similar)...my apologies for sideways orientation:
89 Carrera/electrical,..you better check this!
easy to get the door off?\\
Best,
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-01-2008, 04:19 PM
