Jess
Guest
Posts: n/a
Question Turn signal problem
Here's the situation:
My turn signals were working until very recently. Now they do not but they do display an interesting quirk. With the car running, there are no turn signals. If I turn the ignition off and activate either the left one or the right, the lights will go on but not blink.
I guess I can turn the car off when I want to change lanes or turn and rapidly activate/deactivate the switch but this seems like a very basic problem to fix.
The only possibly related thing that I may have screwed up is that I just changed out the tach. I have checked the turn indicater bulbs in the tach and they are good. All of the wiring at the tach appears good and I'm pretty sure that I installed it correctly. (It works.)
Car is a 77 911.
Any suggestions would be very appreciated!
Jess
Old 04-24-2001, 04:09 PM
magilla
Guest
Posts: n/a
Post
Sounds like its time for a new $95 turn signal switch....
I replaced mine when I first got the my SC.
Magilla
Old 04-24-2001, 04:21 PM
nhromyak@yahoo.com
Guest
Posts: n/a
Post
With the ignition off, this sounds correct.
Check your turn signal flasher relay?
Nick
Nick Hromyak
'85 Carrera 7 & 9 Fuchs
Havin' Fun in
Sacramento CA
Old 04-24-2001, 04:39 PM
Jess
Guest
Posts: n/a
Post
Nick,
That's what I was thinking. Problem is I don't know where the relay is. On my SC it's above the fuses but it's not there on my '77.
I have the Bently book for the SC but I don't have many technical resources for this track car.
Jess
Old 04-24-2001, 04:45 PM
nhromyak@yahoo.com
Guest
Posts: n/a
Post
As I recall, the flasher is behind the tach. I think it is a tall square relay looking thing. Not sure, though it might be a small silver round one.
I remember my '73 having the tall black square one.
Perhaps Warren can chime in..?
Anyone else with a mid 70s 911?
Perhaps you can just go to your local auto-store and ask for a flasher, see what it looks like and then look for that under your dash (behind the tach)
Nick Hromyak
Havin' Fun in
Sacramento CA
Old 04-24-2001, 05:32 PM
Jess
Guest
Posts: n/a
Post
Thanks very much Nick!
This makes a lot of sense, since I was just monkeying around behind the tach. There's an extremely good chance that I knocked a wire off of the relay if it's back there. I'll take a look and let you know.
Jess
Old 04-24-2001, 07:03 PM
john walker's workshop
Guest
Posts: n/a
Post
it's in front of the fuel gauge. accessable either from the front trunk or pop out the gauge. a rectangular 4 terminal unit. the lights that stay on with the key out and the T/S switch left or right are designed as a marker to protect your car at night.
Old 04-24-2001, 07:04 PM
