915 diff magnetic carrier disc needed
hallo everybody!i'm new here.i'm trying to get back to life 1984 3.2 carrera.i noticed that magnets from carrier disc are missing,can anybody help with them?or maybe i can use any othet magnets?
The first thing I would recommend is to look for the missing magnets to make sure they don't cause any expensive damage to the internals of the transmission.
Ed 1973.5 T |
i've already changed whole differential.Don't know was this because of the magnets or not,but the differential was completly damaged
and now i'm looking for magnets,or carrier disc ....
Second on finding the missing magnets. If you can find the same dimension magnet, you can expoxy them in place. I have a disk with three good magnets, let me know if you want it. Good luck
i'm from Georgia(small country near Russia)in my country i can't find anything for this car and magnets with the same dimension are problem too,i bought differential from canada,but there was no carrier disk
Post the transmission numbers from the bottom rib, maybe the differential you bought from Canada is for mechanical and not electrical speedometer drive.
Ed 1973.5 T |
it doesn't really matter,everything is already bought and ready to fit,but the magnets
If the transmission you bought is an early model with mechanical speedometer drive, then the disc for the magnets would not work any way. You would need to install a speedometer cable and matching speedometer.
Ed 1973.5 T |
Naw, he doesn't have a mechanical speedometer transmission. This is for a 3.2, and it was just the differential he bought from Canada. He has the proper carrier plate from his old, damaged, diff, but it is missing magnets.
I've got the magnet plate for one of these, but sending it to far away Georgia is more of a project than I'd like to try. Jojy, perhaps you could contact one of the various places in the US, or Britain, or Germany, which sell used Porache parts, and see if anyone has this plate. They should be quite used to international commerce and shipping. |
gearhead
I've got one. $80. It is probably going to cost more than that in shipping...
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Senior Advisor
Isn't Georgia next to Alabama?
08 Cayenne Turbo |
gearhead
i took the parts from new one and put them together into old differential,everything is ok now,but i'm looking for magnets,maybe state Georgia is next to Alabama,but the country where i live is a litle bit far away from US.I'm looking for it everyewhere...........
