idc1873
G50 clutch
Anyone know the wear limit on a G50 clutch centre plate & what is the plate thickness when new.
HI coxy
Hear you go!! for educational purposes only! ![]() regards mike
Regards mike 1983 911 SC sport, 1982 mini city |
idc1873
Anyone have the same specs on a Turbo Clutch? The PO of my car went with the turbo model and I think it's still well in spec but I'd like to confirm.
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Schleprock
Unless someone has the exact spec for the Turbo clutch disc, i'd use the same specs for G50 disc. Figure based upon the tech information shown, you can expect ~ 1mm thickness of lining material above the rivets. Put a depth gauge into you clutch disc and see how much you've got above the rivets, since the rivets are typically a "gauge" for replacement- if you're wearing on the rivets, time to replace clutch disc.
Kevin L '86 Carrera "Larry" |
Kevin, thanks, that makes sense. I've got quite a ways to go before I hit the rivets, IIRC.
