Addl observations of the OEM or Kuehl front condenser vs the thicker DD model.
Even with approx 1/4 spacers needed to drop the rock guard down to accomodate the 1" thicker unit, the condenser now sits flush on the bottom of the guard. Note in last pic that the factory set up has about 3/4" of air space between the bottom of the condenser and the rock guard providing an addl margin of protection. Spacers needed to drop cage http://forums.pelicanparts.com/uploa...1207308998.jpg http://forums.pelicanparts.com/uploa...1207309574.jpg Desert Duty mounted - rock guard flush with bottom of condenser http://forums.pelicanparts.com/uploa...1207309083.jpg Air space between cage and condenser. Condenser sits above the crash bar in the factory set up. http://forums.pelicanparts.com/uploa...1207309152.jpg |
Mark- what was you ride height at the time of the RR. track impact, factory or lowered? Also, do you have 16 inch wheels or low profile 17 inch wheels?
I started working on removing all of my components this month and bought the DD condenser- I'm at stock ride height but 17 inch wheels- hoping to avoid a similar fate with my brand new DD condenser. Can the crash bar itself also be lowered a bit? It seems like it would be much stronger than the cage in this situation. Sorry to hear of your brand new condensers fate...:( |
What adjustments need to be made to the Expansion Valve to handle R134. I bought the new Rennaire Evap from Pelican and it came with a new Expansion Valvue. Also bought the procooler, barrier hoses, dessert duty, sanden 507, and a new rear lid condensor...
I don't think you have to adjust it, and I don't see an adjustment on it.
I have the same kit, but I'm reusing the origonal 930 halfbay rear condenser and put a 10" fan under it since the serpentine ones are so $$. If you bought the kit new from Rennaire I think they ask you what refrigerent you plan to use when you make the order. Call them before you install it to be sure. 830.522.0300 |
bought from Pelican, but didnt buy the kit... did seperate because I ordered over a few months and changed my mind and added some things as I went along... does anyone have clear documented pics of the hose mounting and procooler install?
http://forums.pelicanparts.com/porsche-911-technical-forum/304231-let-ac-fun-begin-oh-blow-45-a.html |
The hose coming in from the top is coming from the front condensor to be filtered in the reciever dryer portion of the procooler. The hose that travels by to the left and doesn't hook up to anything in the picture is the high pressure hose coming from the rear condensor and going to the front condensor. The other hose conected to the top of the procooler goes to the expansion valve and then through the evaporater to chill everything... The big hose on the side comes from the evaporator to cool off the procooler, and the bottom hose is the low pressure or suction hose and it returns to the compressor.http://forums.pelicanparts.com/uploa...1207712832.jpg |
I'm curious why instead of a ProCooler why can't you use a small heat exchanger with the cool evap. return on one side and hot high side on its way to the expansion valve? Maybe there would be too many connections and parts..to fit in the wheel well. If you used a separate small heat exchanger then you could use a standard r/d.
I did just about everything you've done to your AC system and it still didn't blow enough cold air to my satisfaction. (the air was cold but the volume of air coming from the vents was low)
Unfortunately, I had a dealer installed underdash vent system that originally required the dealer to remove the knee pads and then install their under dash unit. I found a factory underdash vent system, a pair of knee pads and what a difference in the stream of air coming from the vents. The factory design is far superior in air flow and worth the investment for those with the dealer unit. It was money well spent. |
yes, yes... exactly - perfect home brew "ProCooler" - thanks for the link..
Project update: Well, unfortunatley nothing to report :(. Charging delayed by weather. Its 56 degrees as I sit here today watching the Masters and doing taxes. And, we're supposed to have a freeze on Tuesday:mad:.
Waiting for for temps of 85+ to charge. Was planning on vacuuming and leak testing this weekend then waiting for warmer temps to charge but could not find the time. Stay tuned |
Well, I spent the weekend getting this A/C project rolling. When it was described as a dirty job, that was a gross understatement. I needed Mike Rowe to help. There must have been a yard of crap inside the front fender,collected since 1980. And the hoses were just as filthy. But, everything is now in a pile awaiting the garbageman tonight.
I pulled the 2 long hoses and got them temporarily clamped until I can get back at it tonight. The eveporator wrap will have to wait until I can find a new capillary tube somewhere as mine was pretty fried. Have to call a few hobby stores to find some tubing, I guess. As I pulled the evaporator box, I made a grisly discovery. There on the bottom was a mummified mouse and a stash of fiberglass insulation as well as a few acorns. Since there are no oaks in my neighborhood, I have surmised that the carcass has been there since I purchased it from the PO whose property was covered in oaks. I actually gagged a bit when I discovered the beast. |
Do you intend to charge the mouse rent ? If the mouse already has a lease are your going to garnish the rental deposit? Is the rental area covered by the federal assistance low income housing policy? We had had one messy fella one year, he left behind rather large chicken bones. No manners whatsoever. |
Kuehl;
I am referring to the protective sleeve which is about .138 diameter. I cannot figure out how he got in there to begin with. A damn acrobat. |
The protective sleeve that goes over the end of the thermostat wire and is then pushed into the evaporator isn't really necessary. My AC guy said it's "nice" but not necessary. When I did my upgrade I didn't use the protective tube and everything is working fine.
You can omit the protective sleeve however we usually find that overtime the capillary tube,
which is filled with refrigerant gas, can break from vibration or from mishandling. When it breaks the gas escapes from the capillary tube and the thermostat switch is then kaput! We provide a new protective sleeve with the Kuehl evaporators, Kuehl Evap shown on host's site here: http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait= N&make=POR&model=911M§ion=VENTac&page=2&bookma rk=12&part_number=10-7517-910-M207 however you can probably find something in a hobby store or online that may have a thin enough wall to allow for fast temperature transfer; the tubing must have a small enough ID as well. When inserting the protective sleeve, with the capillary tube inside, insure you are inserting it through the fins of the evaporator and not into one of the evaporator's tubes; insertion depth for capillary tube is approximately 4" from the end of the tube to the top of the evaporator box. If you wish to read up on the function of the capillary tube its here: http://www.griffiths.com/achelp/achelp2.html |
Everything you ever wanted to know about that little brass protective tube and more right here: http://forums.pelicanparts.com/porsche-911-technical-forum/344568-evaporator-froze-up-again.html?highlight=evap+froze Sorry to hear about your little friend....all I found was a stash of leaves, whirly oak tree seeds, and three box clips. |
| All times are GMT -8. The time now is 05:26 PM. |
