Replace points in 77 2.7 cis
I want to replace the points in my 77 2.7 cis 911. Looking in catalogs, I either need the Ignitor or the Crane Fireball.
Can anybody point me in the right direction?
Old 03-07-2008, 01:05 PM
i use Pertronix 1867
i used a connector block instead of soldering for future quick r&r
some pelicanheads say it'll burn out if ignition is left on for an extended time without engine running. I carry a spare anyway. I don't trust anything electrical being failsafe.
other units, crane etc are successfuly used by pelicanheads.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-07-2008, 01:11 PM
BigEquity's Avatar
I just installed the pertronix in my '77 911s last week. I was a little confused with the instructions they sent in the box with the ignitor. But a quick search of the forums led me here:
http://www.pertronix.com/support/tips/pdf/porsche_cd_diagram.pdf
After I found these installation instructions, the rest was pretty simple. The car has run great since the install.
Old 03-07-2008, 04:56 PM
laughac's Avatar
Send a message via AIM to laughac
Pertronix w/MSD rocks.
2000 Boxster S
2004 330ci convertible
1978 450 SLC
1924 Model T Ford touring
Fleet of Ford Buses, Sedans, SUVs and Limos
Old 03-07-2008, 05:14 PM
MEMBER # 930
waynesco1's Avatar
WHY remove the contact points the only act as trigger for electronic ignition box . just set dwell and you are on your way! the contact set rarely ever pit or fail with recommended maintenance DONT WAIST your time / money !!!!!!!! you will kick your self Took me a day to remove that junk. PORSCHE /dizzy parts are avalible at all parts stores . try buying parts for that junk dont mess with it.
Old 03-07-2008, 07:49 PM
pertronix
I have a 74 2.7, and replaced my points five years ago.with a pertronix unit. it has worked perfectly so far. it was a big improvement over the points.
John Watson
74' 911S
Old 03-08-2008, 11:27 AM
Originally Posted by VA911-77 View Post
need the Ignitor
Pelican sells it.
I've had mine installed for about six years now - no problems.
Points were a mystery to me.
Old 03-08-2008, 12:01 PM
different strokes on what to install.. and most likely it's not necessary, Pertronix is actually more sensitive to burning out than points discounting wear and tear.
anyway here's my connector block for when mine do burn out.
Stock looking wire covering is dual wall shrink tube from www.waytekwire.com.
The connector block is from West Marine and mfg by Blue Sea Systems. I use dielectric.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-08-2008, 01:17 PM
Wer bremst verliert
JohnJL's Avatar
I use a crane cams that the PO included with a box of parts for the car. It worked fine and took 45 minutes with painstakingly slow instructions-following.
A nice cleanup of the circuits like Ronin's panel is a good idea.
Here's mine
2007 911 Turbo - Not a toy
1985 911 Cab - Wife's toy
1982 911 3.2 Indiash Rot Track Supercharged track toy
1978 911 3.0 Lichtbau toy "Gretchen"
1971 911 Targa S backroad toy
Old 03-08-2008, 06:08 PM
