Hello everyone
![]() Right i went out for a drive with friends the other day and went to use my lights to flash them and they did not work,but if i pushed the light stalk forward main beam still works ![]() Any ideas could it be a relay
Thanks JG911 Last edited by JG911; 03-12-2008 at 03:54 AM.. |
Driving member
Probably the stalk. You may need to replace the stalk or it could just be loose contacts/wiring inside.
Do a search and you will see tons of stuff.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Thanks ill have a look over this weekend
Thanks JG911 |
Iv just had a nosey at this problem i have and in normal position with the stalk it's on full beam and if i push it forward it goes to normal beam and when i pull back it don't flash.
Also my fog lights have stopped working is this all 1 problem or 2 ?
Thanks JG911 |
