jj4u3's Avatar
Question tach problems with 3.2 conversion
I know there is a lot of reading about this but I am a novice and I don't understand most of it. I have a 1972 911T and in the middle of a 3.2 conversion and can't get the 1972 tach to work. Do I have to get a latter model tach or is there something specific that my mechanic is missing
911 - 1972T
Old 03-13-2008, 07:55 PM
Porsche fanatic
jager911's Avatar
When I did my 3.2 conversion back in '03 on my '74, I had the same issue. I used the violet wire and black wire from the 3.2 harness to the tach. I think there are 2 terminals on the tach. I switched to the other terminal to get it to work, I can check tomorrow. I also have the wiring documented for the 14 pin connector if you need help.
'56 Speedster Guards Red
'74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW
'95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed
'74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold
Old 03-13-2008, 09:36 PM
jj4u3's Avatar
I would appreciate any help that I can get on the wiring for the tach
911 - 1972T
Old 03-14-2008, 03:34 AM
What?!?!
DonDavis's Avatar
*EDIT:*Apparently some say an early tach can be used. Not sure if any modifications are needed
An original '72 tach CANNOT be used. It must be a Carrera '84-'89 tach. Use the original power (red/black wire) connected to pin 5 and the original ground (brown wire) connected to pin 6 on the new tach. Then tape up the original black/violet wire and ignore it.
Ok, here's the wiring for the 8 wires that run foward from the DME relay and the "brain".
Yellow- goes to the ignition terminal #50
Black/violet- pin 2 on Tach
Black- .75 mm wire, needs terminal #15 switched 12v
Black- 1.00 mm wire, pin #3 on the Tach, it's the "upshift light" and not needed unless you've also swapped transmission and speedometer from the donor car. Don't worry about it.
Red/green- feeds the fuel pump via fuse panel 25Amp fuse #3
Red- 4.0 mm wire, positive battery terminal
Black- 2.5 mm wire, needs switched 12v via terminal #15
Green/yellow- A/C, not used
Refer to the factory or Bentley schematics to find the "# terminal" locations if needed. I chased this same issue FOREVER! The tach signal comes from pin 21 on the brain. Put an O-scope on there and you should see a varying duty cycle square wave.
Good luck and let us know how you do!
Oh, and next time post pics of your car!!
running shoes, couple tools, fishing pole
1996 Subaru Legacy Outback AWD, 5speed
2002 Subaru Impreza WRX, 5speed
2014 Tundra SR5, 4x4
1964 Land Rover SII A 109 - sold this albatross
Last edited by DonDavis; 03-14-2008 at 03:03 PM.. Reason: Added first line regarding early tach use
Old 03-14-2008, 07:19 AM
AutoBahned
RWebb's Avatar
"It must be a Carrera '84-'89 tach."
- Not sure what this is based on. My 1973.5 tach works just fine - BUT I use an msd. Maybe he is referring to the Bosch silver CD box.
There are dozens and dozens of threads on how to get things working & what does not work. Do a Search!
IIRC, around 1970-71 and older tachs need to be replaced, but not '72 -- you never know tho, P AG could have used an older tach in a '72 car.
Old 03-14-2008, 12:13 PM
copbait73's Avatar
I agree, it will work. I used the stock early model tach but off the top the top of my head I don't remember how it was wired. I know the stock Porsche box was retained.
Old 03-14-2008, 01:11 PM
What?!?!
DonDavis's Avatar
If an early tach can be used, then go for it. When I did my swap, the engine came with a tach and all I had heard was a later tach was needed.
I've edited my earlier post.
Old 03-14-2008, 03:05 PM
AutoBahned
RWebb's Avatar
and please post back to fill in the data on what works with what & how (i.e. msd vs. Bosch, etc.)
Old 03-14-2008, 03:12 PM
jj4u3's Avatar
Thanks for the input guys. I will try the old tach but I have located a newer one just in case I can't make it work
so far no luck with the old one but that may be me
911 - 1972T
Old 03-14-2008, 07:58 PM
