Sorry to hear about your setback. Its frustrating but just hang in there, awesome work Tony.
Gert |
Well heres the latest update following my rookie mistake when I forgot to add hardener to the primer....I had to call in a proffesional and lucky for me he does house calls..........Soda blasting, all I can say is the the stuff is awesome.
and the owner is a PORSCHE/VW enthusiast. Here are some pics and should be priming next week, since i am gonna spend about a week cleaning her up. http://forums.pelicanparts.com/uploa...1216791656.jpg http://forums.pelicanparts.com/uploa...1216791775.jpg http://forums.pelicanparts.com/uploa...1216791828.jpg |
Thanks for sharing through your frustrations. What is uncured primer like? It seems like it kind of dried no? It's probably easier to take off that way.
Keep up the good work. Tim K |
what a bummer man... I'll bet the neighbors were wondering what was that white cloud bubbling up and away from your yard and heading towards them...
I hope he did not use that quickrete on the ladder in his gun to get your job done faster...;-) Hang in there... water works well to clean up the soda on your property... as for your tub, probably use a vacuum & compressed air. Your first painting step will start with a solvent wipe down and the other prep steps I am sure you did. Good luck Bob |
Wolverine, what did the on-site soda blasting set you back? I'm only curious for those who may be headed down this path.... I own a 100lb soda blaster and have found that the soda is costly.....like $24/50lb bag. If I had to guess, I got about $2K in blasting equipment and have a pallet of soda (about $1400) waiting to finish up my tub...
Keep up the great work and keep posting the pics. Peace, Einar |
That stinks about the primer, but I'm amazed they have someone who will come to your house to blast it off the tub... how much longer until we have a traveling Pelican Parts store?
I gotta believe that this is not legal in all 50 states...in fact in today's mindset of "green", I find it hard to believe that anyone does this at all. Doesn't look like fun cleaning that stuff up....
You can always build a blasting booth in your garage!!
http://forums.pelicanparts.com/uploa...1216869982.jpg |
But remember, the soda is removing a not-so-friendly material, primer, which also was on the ground and in the air when he was done. That was also hosed off with the baking somewhere. That is what I refer to. My guess is that if you called your local EPA office and told them you were blasting primer off a car in the outdoors, they would've had more discussion. You cannot even sand WOOD on a boat anywhere near the shoreline in California without risk of citation. Don't get me wrong, I'm no tree-hugger, but I see all of the things that are frowned upon now....my guess is this is one of them. |
I like Soda - and looking forward to your progress.
subscribed! thank for posting...do you have a picture of the color you are going with?
http://forums.pelicanparts.com/uploa...1216963720.jpg |
More pics of this car THAT IS SEX!
Love the Gulf livery!!!! Any updates since soda blasting?
I got my blasting finished yesterday and am now being told (by the local dupont dealer that I have to do special clean up to the bare metal to put a self etching Direct to metal primer on it....you having these issues too?? Peace, Einar |
I just finished using a 50/50 vinegar and water solution to spray the car with and then just rinsed it down with water.......i'll probably run a quick D/A sander over it..... then i'll be wiping the car down with laquer thinner and tack cloth..
upon hosing it down iin the sun, I never seen flash rust develope so fast in some aeras.....wow |
sanding
put the da away and and block
Here's what I'm going to be doing the next time I'm there: http://forums.pelicanparts.com/porsche-911-technical-forum/262049-metal-conditioning-epoxy-priming-101-a.html
(From Freddie's bodywork 101 series) Tim K |
| All times are GMT -8. The time now is 07:40 AM. |
