Guest
Posts: n/a
Anyone out there have a spec book for the 1982 SC who could quote me the front and rear brake rotor specs - new, machined to, and minimum.
I understand the minimum thickness is stamped on the inside flange, but I was not planning on removing the calipers just yet (pads are good for a few more events). Thanks in advance, Mike |
Guest
Posts: n/a
The rotor specs are listed on the link listed below which is located in the Pelican Parts Parts Catalog under brakes/rotors. Hope this helps.
Eric 83SC http://www.pelicanparts.com/catalog/shopcart/911M/por_911M_brakes_main.htm |
Guest
Posts: n/a
Actually I was looking at my rears the other day and I noticed that the min specs were stamped into the OD of the hat section. I forget what it said exactly, but it did have the min thickness.
