AutoBahned
Flywheel fit into Bell Housing
Does anyone know how far the flywheel needs to go to fit into the transmission bell housing?
I am thinking of using a 3.2L flywheel with a 1973 915 tranny, and am concerned that the DME teeth might interfere with the depth to which the flywheel can go. That would prevent mating of the two units. It looks like the flywheel will go about 2 cm into the housing -- just putting the loose flywheel in to test. |
I can't answer your question, but I curious as to the circumstances to why you are doing this. Are you mating the 915 to a 3.2 or just using the newer flywheel on the 2.4??
John Snodgrass 1973 Porsche 911 "Barney" (race car for sale) 2008 Nissan Maxima - Daily Driver 1999 F350 Diesel Crew Cab - Tow Beast 1990 Airstream 36' Land Yacht - Home Away From Home |
PRO Motorsports
A simpler answer is that the 3.2 flywheel will fit along with either the steel or aluminum pressure plate to any 915. You just need to cut the bell housing to clear the crank sensor. (assuming we aren't talking about a G50 flywheel here)
BTW, don't bother cutting it for the top sensor, as this can be eliminated. It was only there for the factory to check the timing prior to delivery.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer) '72 911T Targa MFI 2.4E spec(Formerly "Scruffy") 2004 GT3 |
AutoBahned
Thanks Tyson!
I have a carb'd 3.2L motor with dual 964 distributor (twin-plugged), so need for crank sensors. It is an '84 engine so no G-50 issues. I am mating it to a 915 transmission. Let me know if there is any big advantage to using the Fidanza flywheel or something... it is intended to be a hot street motor, not for a track. |
Some Bad talk about the Fidanza Flywheel here: lightened flywheel?
Also, you may want to read this: http://www.pelicanparts.com/MotorCity/marcesq1/ |
Are you using the crank sensor anymore? I would say no with carbs and 964 dist. What I did was cut off the crank trigger teeth on the flywheel and did not have to cut into the bell housing since I am not using the stock sensors (my sensor is on the front). This helps with the clearance, although it fit either way. Hope this helps.
75 911 Indian Red- RUFWAN2B 2000 Boxster 2000 & 2007 Dobies www.stahlwerks.com Cages and preparation for your Porsche “People who never make mistakes must get tired of doing nothing” Bill : The origin of the orgy of Porsche |
Schleprock
Just want to be sure everybody knows what Tyson is talking about. He's not referring to the upper sensor of the group of two, which sit at ~ 2 o'clock on the bellhousing area- both of these are needed. He's referring to the diagnostic sensor which sits at 12 o'clock atop the bellhousing. It's a sensor that's mounted horizontally to the engine case with two M6 screws and fits between the engine sheetmetal/tin shrouding.
Kevin L '86 Carrera "Larry" |
AutoBahned
I could have a machinist cut off the DME teeth on the flywheel. But it seems like [a] you then introduce a rebalancing issue, and [b] shouldn't I have sold it to someone that needed those teeth (in a fit of public interest activity) and bought an SC flywheel for myself...
BTW - if anybody has an SC flywheel for cheap, let me know. |
Do the 3.2 and 3.0 have the same bolt pattern at the crank? I believe I was told they don't, that's why I did what I did.
