Wierd VIN problem - help?
Looked at an 82 SC targa today...
Am really puzzled by the VIN numbers. The VIN numbers on the plaque on the windshield pillar and the sticker on the door jamb are the same: WP0EA0910CSXXXXXX I looked at the 'Red Book' and it shows that the ninth digit should be a 'C' instead of a 0 (zero). (...091CCS...). It's definitely a 0 (zero) on the plaque and the sticker. The BIG PUZZLE, though is that on the stamped VIN in the trunk, the VIN is: WP0ZZZ91ZCSXXXXXX (ALL THE X'S are identical in both numbers) What in the world is going on? Why a ROW VIN stamped in the trunk with all other numbers different USA system? Also, it has a sticker on the engine apron on the left side next to the tire pressure sticker with the first VIN (not ROW) - never seen this Is this a grey market car? The door jamb sticker looks genuine - mfg date showing of, 03-82. The engine type is 930/16, which is a USA type, not ROW (according to the Red Book). Please help. Thank you for any help you can give me. Sorry this is so long, didn't want to leave anything out. Last edited by tcar; 03-23-2008 at 06:03 PM.. |
sudo apt-get purge 930
Looks like the body was originally going to be a Japan car but ended up being a US car instead.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Well, it is a Left hand drive car, not right hand... FWIW
![]() Just think it's really bizarre. |
Hmmm, just realized. WP0ZZZ91ZCSXXXXXX should be a Japan coupe not a Targa.
Administrator
Um, unless I'm missing something, there's nothing weird here at all.
The ZZZ and the additional check digit (the 9th digit) are placeholders that are changed when a chassis is finally designated for delivery in a particular country (one that isn't in the ROW group, that is) on the production line. As I understand it, all 1980-and-later 911s have the combination of 'provisional' generic/ROW ZZZ stampings and then the 'final' VIN in the locations you mention. So the ZZZ changes to the USA (EA0) code when the car is designated for US/Canada delivery. And the 9th digit has to change when the letters in the VIN are changed. If you're interested, you can see how to calculate the 9th digit here. To translate Porsche 911 VINs up to 1990, check this page
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
OK, that helps.
The Carfax was OK on the car, so I was wondering what was going on. So they would stamp the ZZZ number on the chassis until they knew where it was going? I've never seen this, the chassis stamp has always been the same as the VIN. |
My '84 is the same way.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Jack Olsen, I think the 18 digit VINs started in 81 with a 'B' in the 10th digit.
My 80 still has the old short VIN. |
Administrator
I've never heard of an 18-digit VIN. I think they've been 17 digits/characters since 1981. Before that, there wasn't an industry-wide standard for creating the numbers. But then, I've also heard that the 17-digit numbers were going to all be used up pretty soon, so maybe that's changed.
Oops. Typo. Meant 17 digit...
So, the other question...
Is there an error in the famed Red Book? I looked at the Red Book and it shows that the ninth digit should be a 'C' instead of a 0 (zero). (...091CCS...instead of 0910CS). It's definitely a 0 (zero) on the plaque and the door jamb sticker. Carfax also says it's correct with a '0'and not a 'C'. Is the Red Book in error? |
You might want to re-check "The Red Book" information. I've used it and have found it to be very reliable regarding VIN numbers and how they're presented. The ninth digit is a placeholder. The 10th digit is the model year, "C" in your case, which means 1982.
While you're checking, look at the engine serial number. It's third digit should be a "C" for 1982 production as well. More vehicle identifcation information here. "C" and "D" production 911s are the best of the SCs, but, hey, I'm biased. ![]() Brian
'82 SC Targa '83 SC Cabriolet |
WP0EA0910CSXXXXXX
according to Bruce Anderson's book: WPO= World Producer code EAO(not zero but letter O) = VDS code 91 = 911 0 = Test digit C = 1982 S = Stuttgart 1 = 1 (last 1 for 911) x = body and engine code. ie: 2 = USA 911 SC xxxx = sequential serial number Total is 17 digits.
Tony G 2000 Boxster S |
That's what I'm wondering is an error.
The Red Book shows the 9th digit should be a C, not a 0. |
Yep, it does. Hmmm.
