			 Nobody
				Does the shift lever have a bend at the base? SEE PICS
			Is the shift lever suppose to be bent at the bottom? The one I received in the mail does not match the one I have in the car.
			No, it should straight in the area you have marked.
			 Member 911 Anonymous
			+1, what kind of shifter is that?
	'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC  |
			 Nobody
			Thank you gentlemen.
			DRACO - according to the seller a "1968 912 shifter". Last edited by bob tilton; 03-29-2008 at 11:40 PM..  |
			 Insert Tag Line HERE.....
			cant tell by the pics, but is it a 'burned' portion where its bent? If so, looks like someone heated it up and bent it forward for some reason.
