degreeoff1's Avatar
Question Toluene?
OK before you tell me to seach....I have with few direct responses to the "T" factor...I am running carbs with NEW SS fuel lines (rubber lined) AN stuff. Will it be cheap insurance against detonation?
1972 914-6 in the works.....
2003 Ford E-250 "work horse"
2004 Yamaha V-star Classic 1100 "early mid life crisis"
2005 Scion XB "Gas sipping"
1978 Siedelmann S25 "Ataraxia"
Old 03-31-2008, 07:48 AM
There are searches and there are searches. Google "toluene octane" and you'll get a ton of responses from people using it.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 03-31-2008, 08:04 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
I'm not certain how the lines will hold up to it but toluene/xylene blends are a trick among 951 tuning guys to run higher boost levels. I think some of the guys run up to 25% blends. I never ran higher than about 3 gallons in a full tank (+/- 13%) and got great results all the way up to 22 psi.
Black Cars Matter
Old 03-31-2008, 08:09 AM
Black Cars Matter
Old 03-31-2008, 08:10 AM
Bill is Dead.
cashflyer's Avatar
http://www.elektro.com/~audi/audi/toluene.html
Old 03-31-2008, 08:38 AM
degreeoff1's Avatar
I have done those seaches, I guess what I was after was a little first hand porsche 911 experience.
Old 03-31-2008, 09:01 AM
Zeke's Avatar
I have some first hand air cooled experience as I used a head temp and exhaust temp gauge setup on my kart and used a bit of toluene. It runs hotter.
Old 03-31-2008, 09:29 AM
Crotchety Old Bastard
RarlyL8's Avatar
The vapor pressure of toluene is much less than that of ethanol, for example. Both increase octane rating but toluene will run more hot while EtOH runs cooler.
Be conservative with your blending and watch the head temps.
Old 03-31-2008, 10:20 AM
degreeoff1's Avatar
Well I would like to run 10% as a starter. Just wanted to make sure I could. I will run race gas @ tracks or at least a 50/50 there but for spirited street driving my 2.7 9.8:1 pistons with single plug heads might need a wee bit more that 93 Oct.
Old 03-31-2008, 10:53 AM
jluetjen's Avatar
What sort of cams are you running? If you've got something like S cams, 9.8:1 on super is most likely not such a big deal. I used Toluene for a while in my 2.0 with S pistons and E cams (and the result high-CR poor combustion chamber design) and it certainly helped reduce the pinging (and I assume detonation). But it's not like gas isn't expensive enough, and it got to be a drag constantly mixing the stuff. You can't just dump it in the tank like octain booster. It doesn't mix that well with gas, and if you're depending on it to keep the detonation down, you need to be fairly consistent with the mixture. So now that means you're mixing it in external tanks and shaking it up in order to ensure that you get a good mixture.
At the end of the day I ended up retarding my ignition timing some and going back to straight high-octain and my engine has been happy ever since.
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 03-31-2008, 06:54 PM
