Strange clock question
What is the white hand?
A simple placekeeper? An alarm that no longer works?
'84 911, some sort of red color '05 Subaru WRX wagon |
Friend of Warren
Yep just a placekeeper for timing your travels.
Kurt V No more Porsches, but a revolving number of motorcycles. |
1984-911 M491
And here I thought it was a jammed second-hand.
1984-911 TLC......SOLD |
If you do a search, many, many, many think it's a non-working second hand...
Even seen clocks for sale here "second hand doesn't work". Not an alarm either. Concept of elapsed time marker eludes many even after an explanation. |
HAHA Same concept as a rotating dial on a wrist watch. Set the 60 to current time and watch the time fly......
Darren 1973 911 T MFI 2005 997 Carrera 2001 Toyota 4Runner |
Wow.......never imagined that there was that much mystery.
S.
Scott "Houston, Tranquility Base here, the Eagle has landed" Silver 1984 M491 Sunroof Coupe |
I thought it was the 12 hour hand...I set it and when the other two hands get back around to the white hand, I know it's time to stop driving around and go home.
1995 993 Carrera, Guards Red Coupe (current) 1987 911 Carrera, Marine Blau Metallic (06-08) Gone but... 1965 Yellow Mustang Convertible (65-05) __________________________________________ It is always a good idea to keep the pointy end going forward as much as possible. |
Detached Member
You push in the control and turn the hand to whatever you want, its a place keeper for timing something.
Hugh |
An Irish gang from Brooklyn in the early 20th Century.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
placekeepers were very common in airplanes in the past. Since a clock in an airplane has a timing purpose, as well as a "what time is it", it's installed to be a simple way of noting how many minutes until or past. It's made to be easy to set while you are usually too busy, or wearing gloves in the old days, to set a complicated stopwatch.
'82 911 SC |
