How much current starter solenoid line draw?
How much current does the starter solenoid line draw? ...or maybe, how big of a fuse should be in that line? wiring race car.
I installed a remote starter in mine to reduce wear and tear on the NLA ignition switch. Here's some info:
http://members.rennlist.org/911pcars/RemoteStarter.htm I ended up using a 10A fuse, maybe 15A. YMMV depending on compression ratio, starter motor, your custom electrical system variables, etc. That should get you in the ballpark. Hope this helps, Sherwood |
that works! thx
