Removing rear-window defogger lines?
In the past, I was very interested in preserving the rear-window defogger lines while removing my window tint. However, after seeing an RS replica @ Barrett-Jackson this weekend with a clean/clear back window, I want to remove them.
Are there any tricks to doing this without scratching the glass?
Detached Member
Yeah, its just ohmic heating paint (electrical conducting paint). A flat glass scrapper razor blade and a little solvent like Goof off and it will come right off, permanently as in you can't realistically put it back on ever.
Hugh |
or find an early one. lots of pre-69s had them.
19 years and 17k posts...
I'm going to remove these from my rear window also, I really like the look and my rear window defroster has never worked anyway...
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
I used "Goof Off" when removing the tint. It didn't seem to faze the defrost grid. Can I try something stronger (e.g. acetone)?
Art, the defroster harness unplugs in the engine bay. You could run some simple continuity tests to begin finding out why yours isn't functioning. You have a Targa -- the defroster wires are very much a part of the car's presentation. You're still going to have the switch on the dash, right?
I agree with John Walker. Rather than permanently kill a could-be-functional defroster rear window, find an early non-defrost-equipped rear window and swap it in as part of replacing the rear window seal when and if it needs it. Someday preservationists may need period-correct, defroster equipped replacements. Or not. Anyway my 2 cents. ![]() Brian
'82 SC Targa '83 SC Cabriolet |
So...will acetone do it or is that going to screw-up the glass/coating? |
