Thanx for that, it works.
Any chance you'll do one for the 1973?
Please do one for a 1973.
Get me a pic of the original and I'll get it done within the next couple of weeks. :)
I know this is an old thread but wondering if the link could be reanimated? Or does someone have a copy for a 1970E or S?
thanks |
tgittens, I upgraded my O/S a few months ago but forgot to install the web server :)
I'll try to get it going tonight but can't promise since I'm leaving for holiday for a couple of weeks. I could probably email you the files. PM me if you like. |
:eek: You are the man!!!! Finally! I knew someone smart enough would do
something like this, I thought about it :rolleyes: but apparently NOT :D enough noggins to do figure it out. :) ;) :cool: |
Gentlemen:
I too am anxious to acquire the fresh labels. Using Mazilla Forefox I repeatedly get a time-out error when accessing the links that are mentioned. If you can tell me how to overcome this, let me know here, or at deerhal@cox.net. Forward the PDF file? Thanks.- - -Al This is the corresponding information from my 70S that I posted in an earlier thread. ================================================== ==== Fuse Box #1 1 Amp =5, Interior lamp, clock, luggage space light 2 Amp = 16, Warning light 3 Amp = 25, Windshield wiper, windshield washer 4 Amp = 16, Cigarette lighter, auxiliary heater 5 Amp = 16, Sunshine roof, rear window wiper 6 Amp = 25, Window opener 7 Amp = 25, Fresh air blower 8 Amp = 16, Stop-turn-signal and backup light 9 Amp = 5, Blinker light, front left 10 Amp = 5, Blinker light, front right Fuse Box #2 1 Amp =8, High beam left 2 Amp = 8, High beam right 3 Amp = 8, Low beam left 4 Amp = 8, Low beam right 5 Amp = 5, Parking light left 6 Amp = 5, Parking light right 7 Amp = 5, License plate light 8 Amp = 16, Fog light |
Mornin' Gents
I'd appreciate getting the link as well. Thanks in advance Cheers JB |
I'm on holiday for a couple of weeks.
I'll set up the web server when I'm back and let all of you know. |
Managed to do something remotely.
Try this http://popester.homeip.net/FuseBoxLabels/FuseBoxLabels02.pdf and please tell me if it works. |
Pope:
Your most recent link worked. Many thanks. Fuse amp level color information regarding our fuses. 1970 911 Fuse Box #1 1 Amp =5, Interior lamp, clock, luggage space light 2 Amp = 16, Warning light 3 Amp = 25, Windshield wiper, windshield washer 4 Amp = 16, Cigarette lighter, auxiliary heater 5 Amp = 16, Sunshine roof, rear window wiper 6 Amp = 25, Window opener 7 Amp = 25, Fresh air blower 8 Amp = 16, Stop-turn-signal and backup light 9 Amp = 5, Blinker light, front left 10 Amp = 5, Blinker light, front right Fuse Box #2 1 Amp =8, High beam left 2 Amp = 8, High beam right 3 Amp = 8, Low beam left 4 Amp = 8, Low beam right 5 Amp = 5, Parking light left 6 Amp = 5, Parking light right 7 Amp = 5, License plate light 8 Amp = 16, Fog light 5 amp = Yellow 8 Amp = White 16 Amp = Red 25 Amp = Blue Al |
Hi, Would this be the same fuse relay diagram for an 86 Carrera? I need this label as well.
I went home past midnight and drove around 60 miles. I seem to have lost my low beam and drove an hour using bright beam. You can just imagine how irritating it was for those in front of me last night. Luckily it was 1:30am and a few cars were on I-294. I want to know where the low beam fuse is so I can check it out. Would appreciate if somebody has a scanned version of the fuse relay diagram for an 86. Thanks |
JQ911, sorry that label is for the early cars, yours is glued to the outside of the fuse cover but I think that it is still available from Pelican
Lorne M. |
Just to update the link to my server.
Hope it's working. Whoever needs the file and can't get it, PM me. http://popester.dlinkddns.com/FuseBoxLabels/FuseBoxLabels02.pdf Don't know why I cannot edit my original post.. |
There is a time limit on threads after which editing is disabled.
Here are some pictures of 1973 Rear Panel directory if you can use them. http://forums.pelicanparts.com/uploa...1405278234.jpg http://forums.pelicanparts.com/uploa...1405278250.jpg |
Thanks Ed.
What is the size of the first one? The second one is already in the pdf file. |
Unfortunately I don't know. The picture of the paper one is from another member. It did fit inside the rear 3 fuse cover, which I do not have one of to measure.
resurrecting this from the dead - I am after the labels for a 72S. Did anyone keep copies of the files as the link seems dead now. I have half of my original for the big box, nothing for the middle box and 75% of the 3 fuse label.
Would like to print them all out nicely..... Thanks |
| All times are GMT -8. The time now is 04:41 AM. |
