As you were!!
i just clicked on the link again and it works! I must have done something wrong the first couple of times! Excellent DIY resource! |
link is working
good job !!! thanks |
Terrific.
Let me know if you have any issues and I'll see what I can do to help. |
It's not working for me...
It work for me.
If you are at work, might be some security setting. |
No luck here either.
Should be OK now. It was probably DNS's taking a while to sync.
Thank you Pope. This is a great share.
Got it! Thanks Pope
Cheers JB |
Was in a drawing mood tonight so added an attempt at E Sully's 73 in case he or anyone else needs it.
http://pope.go.ro/FuseBoxLabels/FuseBoxLabels03.pdf |
Fuse Box Labels
Hi, All
Looking for the template for 1973 911. Here's what I have from fuse boxes: Fuses on 1973.5 911 Top Fuse Box Fuse (amp) Circuit 1 5 – Yellow luggage/glove box light, interior light, clock 2 16 - Red warning light 3 25 - Blue window opener 4 16 – Red cigarette lighter (aux. heater) 5 16 - Red sunroof, (rear window wiper) 6 25 - Blue windshield wipers, windshield washer motor 7 25 - Blue fresh air blower, rear window defroster 8 16 - Red stop, turn signal & backup light 9 5 – Yellow front L. blinker light 10 5 – Yellow front R. blinker light Bottom Fuse Box Fuse (amp) Circuit 1 8 L. high beam 2 8 R. high beam 3 8 L. low beam 4 8 R. low beam 5 5 – Yellow L. parking light 6 5 – Yellow R. parking light 7 5 - Yellow license plate light 8 16 - Red (fog light) Rear Fuse Panel Fuse (amp) Circuit 1 5 - Yellow 2 8 Ignition box 3 25 - Blue 8 amp fuses are white And a photo: http://forums.pelicanparts.com/uploa...1521457153.jpg Thanks for the great effort! |
Maybe you can get a higher resolution picture of the 10 fuse label? Some of the text is illegible.
The second one is the same as the 1970-72. |
Fuse Box for 1973 911E
My fuse box matches Page 4 on the attached link that you have just recently provided, with one change: the #4 fuse (windshield wiper) is in the #6 fuse (cigarette lighter) position and visa versa. In other words, all is the same except fuse #4 is in the #6 position and #6 is in the #4 position. The other 8 fuses, per the diagram on Page 6, are exactly the same. Does this help? The car is a 1973 911E. Thanks very much SmileWavy |
Actually, fuse 7 is also different and fuse 1 which is probably the same electrically, is described differently.
So my problem in completing this correctly is that I can't read the German and French for fuses 1 and 7. |
Deutsche English Français |
Yes, you're correct. They are in 3 languages. I will try to get the details in French and German today. English is easy!
Pope
Here's what I can read from the cover: #1 Innen-Kofferraum- Hand- schuhkastenleuchte, Zeituhr luggage/ glove-box-light interier light, clock ecl. linter. / coffre a bag. / boite a gants montre #7 Frischluftgeblase Helais Heckheizscheibe fresh air blower rel. -heated rear window soufflerie ar frais rel -lunette ar. -chauf. |
Thanks Pope for your assistance with this...It is the best I can read it given age and wear.
Thanks again |
Yeah, I think that's good enough.
Have a look here: http://pope.go.ro/FuseBoxLabels/FuseBoxLabels04.pdf Let me know if it's OK and if you need anything else. |
| All times are GMT -8. The time now is 04:40 AM. |
