As you were!!
i just clicked on the link again and it works! I must have done something wrong the first couple of times!
Excellent DIY resource!
Old 11-23-2016, 10:55 AM
link is working
good job !!!
thanks
Old 11-23-2016, 03:29 PM
1-6-2-4-3-5-1-6-2-4-3-...
pope's Avatar
Terrific.
Let me know if you have any issues and I'll see what I can do to help.
'70 911E Coupe, Webers 40IDA
Old 11-24-2016, 02:23 AM
pope's Avatar
NEW LINK
http://pope.go.ro/FuseBoxLabels/FuseBoxLabels02.pdf
Old 10-03-2017, 05:48 AM
Burnin' Rubber
Koizumi's Avatar
It's not working for me...
Old 10-03-2017, 08:51 AM
83 911 Production Cab #10
JJ 911SC's Avatar
It work for me.
If you are at work, might be some security setting.
Who Will Live... Will See
Old 10-03-2017, 08:54 AM
Ubi bene ibi patria
Hawkeye's-911T's Avatar
No luck here either.
“Two possibilities exist: either we are alone in the Universe or we are not - both are equally terrifying” ― Arthur C. Clarke
"As soon as laws are necessary for men, they are no longer fit for freedom." - Pythagoras
Old 10-03-2017, 09:38 AM
pope's Avatar
Should be OK now. It was probably DNS's taking a while to sync.
Old 10-14-2017, 12:02 AM
echecsqueen's Avatar
Thank you Pope. This is a great share.
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 10-14-2017, 09:13 AM
Ubi bene ibi patria
Got it! Thanks Pope
Cheers
JB
Old 10-14-2017, 10:35 AM
pope's Avatar
Was in a drawing mood tonight so added an attempt at E Sully's 73 in case he or anyone else needs it.
http://pope.go.ro/FuseBoxLabels/FuseBoxLabels03.pdf
Old 10-14-2017, 01:36 PM
Vintage56's Avatar
Thumbs up Fuse Box Labels
Hi, All
Looking for the template for 1973 911. Here's what I have from fuse boxes:
Fuses on 1973.5 911
Top Fuse Box
Fuse (amp) Circuit
1 5 – Yellow luggage/glove box light, interior light, clock
2 16 - Red warning light
3 25 - Blue window opener
4 16 – Red cigarette lighter (aux. heater)
5 16 - Red sunroof, (rear window wiper)
6 25 - Blue windshield wipers, windshield washer motor
7 25 - Blue fresh air blower, rear window defroster
8 16 - Red stop, turn signal & backup light
9 5 – Yellow front L. blinker light
10 5 – Yellow front R. blinker light
Bottom Fuse Box
Fuse (amp) Circuit
1 8 L. high beam
2 8 R. high beam
3 8 L. low beam
4 8 R. low beam
5 5 – Yellow L. parking light
6 5 – Yellow R. parking light
7 5 - Yellow license plate light
8 16 - Red (fog light)
Rear Fuse Panel
Fuse (amp) Circuit
1 5 - Yellow
2 8 Ignition box
3 25 - Blue
8 amp fuses are white
And a photo:
Thanks for the great effort!
Old 03-19-2018, 04:00 AM
pope's Avatar
Maybe you can get a higher resolution picture of the 10 fuse label? Some of the text is illegible.
The second one is the same as the 1970-72.
Old 03-19-2018, 07:08 AM
Vintage56's Avatar
Fuse Box for 1973 911E
My fuse box matches Page 4 on the attached link that you have just recently provided, with one change: the #4 fuse (windshield wiper) is in the #6 fuse (cigarette lighter) position and visa versa. In other words, all is the same except fuse #4 is in the #6 position and #6 is in the #4 position. The other 8 fuses, per the diagram on Page 6, are exactly the same.
Does this help? The car is a 1973 911E.
Thanks very much
Old 03-26-2018, 05:40 AM
pope's Avatar
Actually, fuse 7 is also different and fuse 1 which is probably the same electrically, is described differently.
So my problem in completing this correctly is that I can't read the German and French for fuses 1 and 7.
Old 03-26-2018, 11:13 PM
JJ 911SC's Avatar
I though they were labeled Trilingual's
Deutsche
English
Français
Old 03-27-2018, 02:40 AM
Vintage56's Avatar
Yes, you're correct. They are in 3 languages. I will try to get the details in French and German today. English is easy!
Old 03-27-2018, 03:54 AM
Vintage56's Avatar
Pope
Here's what I can read from the cover:
#1
Innen-Kofferraum- Hand-
schuhkastenleuchte, Zeituhr
luggage/ glove-box-light
interier light, clock
ecl. linter. / coffre a bag. /
boite a gants montre
#7
Frischluftgeblase
Helais Heckheizscheibe
fresh air blower
rel. -heated rear window
soufflerie ar frais
rel -lunette ar. -chauf.
Old 03-27-2018, 06:29 AM
Vintage56's Avatar
Thanks Pope for your assistance with this...It is the best I can read it given age and wear.
Thanks again
Old 03-27-2018, 06:30 AM
pope's Avatar
Yeah, I think that's good enough.
Have a look here:
http://pope.go.ro/FuseBoxLabels/FuseBoxLabels04.pdf
Let me know if it's OK and if you need anything else.
Old 03-27-2018, 07:32 AM
Tags
fuse box label
