targa todd's Avatar
Unhappy Engine lid won't open
Surprisingly, a pretty exhaustive search of the forum came up empty on this.
My engine lid won't release. I suspect the cable is bad/loose/disconnected. It had been a bit fishy for a little while (several strong pulls before it would open), and of course I didn't address the problem in time.
So, the $64k question is: how do I get this thing open so I can fix the problem??
The release handle still has tension and I can pull it 1/4 inch or so and it still springs back. It feels like I can't pull it far enough to release the latch. This makes me think that the cable is not broken and perhaps only in need of adjustment - if adjustment is possible.
Anyone know how I can get the lid open?? I CAN'T be the first person this has happened to!
'87 930 - 100% stock
'89 951 - 100% track
'08 Audi RS4 - daily
'85 911 Targa - sold
Old 10-27-2008, 05:11 AM
You could try parking the car on un- even ground and pull the release while someone pushes down on the lid.
Or you could (Last resort) cut the cable and it should open the latch.
Silver 1980SC Euro coupe
Old 10-27-2008, 05:47 AM
targa todd's Avatar
Thanks Ron. Simply putting some pressure on the lid while releasing did the trick. Now, the question is: what adjustments are available to fix this problem? I checked the Bentley manual and came up empty.
Thanks.
Old 10-27-2008, 06:47 AM
78 in a '71
mossguy's Avatar
Todd - While the engine lid is open, cover the latching hole with some masking tape. Put a spot of grease or other suitable "marking material" on the tip of the cone shaped latch. Lower the lid until the latch cone and the tape barely touch, then check to see where the grease mark is. It could be that the latch opening is off center. loosen the latch opening piece enough to slide it around, test the position of the latch cone tip until it is centered in the hole, and tighten.
Tom
On glide path......
1971 911 T Targa
2013 Ford Fusion Titanium AWD
Old 10-27-2008, 06:56 AM
78 in a '71
mossguy's Avatar
Or your engine lid could be off center. Check your lid panel gaps. The whole lid might need positional adjustment.
Tom
On glide path......
1971 911 T Targa
Old 10-27-2008, 06:58 AM
Designer King
Paulporsche's Avatar
Do a search for threads started by me. You will see how I finally did it.
I used a thin steel rule to get between the cover and the body and pushed things around until the lid popped open. I then used a tip from another poster to adjust, but putting a piece of toweling paper over the hole and observing where the plunger pierced it. Works like the tape/grease mark method above.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 10-27-2008, 07:04 AM
