CDI/Ignition Help
Hello all,
I listened for the whining sound at the CDI, however, there was none. I read at www.permatune.com (this is the unit that is there) that they do not whine.
I had no spark at the plug..dist...etc...
The harness going to the CDI had a voltage of 7.5V. The car had 12V at the battery. (this seems like a problem but not sure)
Anyways, I disconnected the tach plug by the o2 sensor....AND IT STARTED! plugged it back....and no start. (The tach is somehow part of the circuit I believe)
THIS is the problem, but I am not sure from here. Is this a problem with the Tachometer itself or the wire leaving the distributor to the CDI? The car will run now but I have no tach. Is it a possible ground problem.
If anyone has been there...done that... please let me know. I did not see anything with my search.
Thanks.
PS car is an 89 930 but I believe the SC 911s had the same set up...plus I hope you guys know more about maintaince than the 930 guys.
Old 04-09-2008, 02:38 PM
Search on here there is a lot of info about the 6 pin CDI on the 930. In your case I guess that you have a fault with the tacho that is grounding the pulses used to fire the thyristor in the CDI unit.
Regards
Old 04-19-2008, 07:57 AM
Somatic Negative Optimist
Gunter's Avatar
I believe that the turbos had an 8-pin Bosch CDI module at some point?
Permatune doesn't have a good reputation for performance or durability, do a search here.
Why not try and find a used 6 or 8-pin Bosch?
Or replace the Permatune with MSD?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Last edited by Gunter; 04-19-2008 at 09:32 AM.. Reason: When did turbos get the 8-pin?
Old 04-19-2008, 08:10 AM
I have an 1985 930 and mine has a 6 pin unit - I have it on the bench right now.
Regards
Old 04-19-2008, 08:16 AM
Gunter's Avatar
That would be even better.
A 6-pin is easier to find.
I wonder if the 8-pin module came in after '89?
Hmm............
Lot's of stuff here:
6-pin SC/Turbo CDI unit repair documentation
Old 04-19-2008, 09:29 AM
