New noise. Whirrrrr hummmmmmmmmm
New noise appeared today that I've never heard before. I noticed it after Autocross.
Coming front the front, near the fuel tank. A loud hum with a slight, slow oscillation. Does not seem to be affected by engine speed. Definately from the front, and it sounds like it's from the right side...perhaps under the right front fender?
Only happens when car is running.
At first, I thought it was the A/C as there is a similar noise when the A/C is running....bu then I noticed the A/C was not running....
No heater on, no A/C running....
I don't know where the fuel pump is, but that's my first thoughts...
If it is....I did NOT notice any acceleration or stumbling issues.
Any ideas? I might have captured this sound on the in-car camera....I'll check and post a clip if so....
edit
Well, after eading quie a bit, I'm convinced it's the fuel pump.
Blast it. Finally new shocks and alignment, and the pump wants to poop itself.
Oh well.
The new shocks and alignment made a HUGE improvement on handling at Autocross today.
'85 911. White - 53,000 miles bought 3-16-07. "Casper"
'88 924S. Blue - 120k miles bought with 105k miles.
'94 968 Coupe - White - 108,000 miles bought 9-28-17
'09 Cayman - Grey - bought 9-8-20
Old 04-12-2008, 05:33 PM
Al S's Avatar
Wolfe, the pump can get quite noisy before it has to be replaced.
Try cleaning the strainer at the bottom of the fuel tank before you do anything else. The mesh is really fine, and after many years it gets varnished and partially clogged, causing the pump to cavitate.
Al Shkuratoff
86 Carrera, SW chip, Fabspeed, M&K
83SC Platinum - Sold
83SC Slate Grey - Sold
Old 04-12-2008, 07:18 PM
MEMBER # 930
waynesco1's Avatar
My fuel pump was making noise so I replaced it and new one makes noise also buzzing sound . yours may be ok . Hope you had lots of fun today ,we had other obligations today and missed out on all the fun at bremerton , will hope to see you next month
Wayne/Kelly
Old 04-12-2008, 07:51 PM
The audio warning signal is a plus, no?
You could have been stranded high and dry in the hinterlands. Instead, you'll be stranded at home. That's relatively better. There's no place like home.
Sherwood
Old 04-12-2008, 08:17 PM
I'll have to get that looked at, thanks. As for touching it myself, hell no. I tend to have rather bad static eletricity problems...I throw random sparks for no reason.
The Audio warning is nice, yes!
Old 04-12-2008, 08:24 PM
