Engine is out, and I've never had this connected. I figured since I'm working other 'issues', i'd figure out what should go here. I do have another lone hose that might belong on this fitting.
![]() I also need to track down the part number on Pelican Parts site for this hose and for my Crankcase Breather hose. I always get into the parts list then don't quite see the hose in the parts breakdown. Any help is appreciated. Thanks ... ted
1980 911-SC Targa |
comes off the front of the throttle housing, vacuum at idle. probably disconnected and plugged, laying back there somewhere, because with it connected, the idle would hang.
Great, it is diconnected and plugged, so I'll track it back to make sure that's the correct dangling hose.
So, your saying keep it disconnected, sounds like a plan. I may clean up the hose and shorten it to tiddy up a bit. Thanks ...
1980 911-SC Targa |
