Free minder
Aurel's Avatar
226 mm fan in 245 mm housing
I have found a replacement housing for my cracked one, but it is a 245mm, while the fan I have is 226 mm. Is there any harm in using this combination? I assume the air pressure will be lower, but I`d like to know if anyone has ever tried that, and what it does to the engine temperature.
Aurel
Old 04-04-2008, 06:52 PM
Danny_Ocean's Avatar
I'm no aerodynamic engineer, but it looks like you'll be "losing" air around the edges. I'm sure an aerodynamic engineer will be chiming in soon, as there are more than a few here.
Old 04-04-2008, 06:58 PM
UnRegistered User
billybek's Avatar
I'm no aerodynamic engineer either, but I play one on the internet!
I wouldn't do it. The tight tolerance on the edge of the fan to housing provides a "seal" that allows the shroud to be pressurized allowing even airflow.
Bill K.
Old 04-04-2008, 07:14 PM
djpateman's Avatar
That is totally unacceptable.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 04-04-2008, 08:20 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Nope. Turbines need to have tight clearance between the shroud and blades. This is no exception. It's better than nothing, but it won't give your engine the cooling it was designed to have.
Black Cars Matter
Old 04-04-2008, 08:30 PM
At least it won't rub.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 04-06-2008, 06:39 AM
Jeff is the ultimate optimist.
Old 04-06-2008, 07:19 AM
Free minder
Aurel's Avatar
Thanks guys. I bought a 245 mm impeller and put the 226 mm one for sale.
Cheers,
Aurel
Old 04-06-2008, 07:55 AM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Location: the border between the states of inebriation & confusion
You did the right thing...
Well, I am a hydrodynamics/hemodynamics research engineer, and I can assure you that the gap between the blade tips and the shroud are a critical parameter for performance. With increasing "tip gap" flow and pressure performance falls off significantly.
Old 04-06-2008, 08:16 AM
Of course, the upside is you won't have to worry about the blades rubbing on the housing.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 04-07-2008, 12:23 PM
There you go...it's official! (Umm...whatz "hemodynamics"?)
Old 04-07-2008, 07:27 PM
dw1 dw1 is offline
R&D guy
dw1's Avatar
Hemodynamics is hydrodynamics, i.e. fluid mechanics, but with blood.
A very important subject for all of us 911 enthusiasts, because doesn't driving or working on your pride & joy make your heart beat faster?
Seriously: http://www.hemodynamicsociety.org/hemodyn.html
Old 04-07-2008, 07:44 PM
Well...actually...working on my car does cause bleeding.
Old 04-07-2008, 08:38 PM
Aurel I have a good 245mm fan to do a trade if you wish.
Send me a PM if you are interested.
Thanks Robert
Old 04-07-2008, 09:13 PM
Richard Burns's Avatar
dw1.
Would changeing a 5 blade fan for an 11 blade fan increase the cooling.
Sorry to hijack the topic.
Thanks in advance.
Life is not a journey to the grave with a pretty and well preserved body but to skid in sideways, used and worn out saying " What a trip!
Old 04-07-2008, 10:26 PM
I suppose if a 245mm fan was NLA at any price, then a clever machinist could fabricate a spacer of sorts to span the gap (only 9.5mm, btw). The shape of the spacer would have to be similar to the opening of the fan housing to smooth the entry of air and not create unnecessary air turbulence at the tip of the fan blades.
Either that or close the gap slightly by powder coating the fan with about 150 coats of paint, then with safety goggles, make sure the paint is really dry before cranking the engine.
Sherwood
Old 04-07-2008, 11:09 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
yeah..nope.
[edited; saw he already got a 245mm fan]
Scott Kinder
kindersport @ gmail.com
Old 04-07-2008, 11:13 PM
Yes. There are a ton of threads on this subject. Do a search for "5 blade fan", etc.
Old 04-08-2008, 06:23 AM
" Would changeing a 5 blade fan for an 11 blade fan increase the cooling.
Yes."
"There are a ton of threads on this subject. Do a search for "5 blade fan, etc."
After looking at 8 pages of the search result, I couldn't find any obvious titles that addresses the question; Why does a 5 blade fan increase the cooling more than an 11 blade fan?
Sherwood
Old 04-08-2008, 09:04 AM
Free minder
Aurel's Avatar
Yes."
Sherwood
I think you got it backwards. A 11 blade fan increases the cooling over a 5 blades fan, because it moves twice as much air. I figure it is equivalent to doubling the speed on a 5 blades fan, but without the added stress on the alternator.
Aurel
Old 04-08-2008, 10:13 AM
